Attic Pull Down Stairs - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-24-2012, 02:15 PM   #1
Attic pull down stairs
Inspector requires that the plywood cover to the pull down garage stairs be covered with 5/8 in dry wall...which is 54 in by 25 inch...most likely that this additional weight will prevent cover to close flush to ceiling and may allow a gap or even keep it from closing altogether...Is the spring tension system going to be enough to tack up the slack ?
Pacer 2 is offline   Reply With Quote
Old 12-24-2012, 02:32 PM   #2
bbo
it might. you may need different springs or a latch.
bbo is offline   Reply With Quote
Old 12-24-2012, 02:44 PM   #3
DIY Enthusiast
sublime2's Avatar
what inspector?
rarely see pull down attic stairs covered with drywall.
Paint the plywood white or what ever color the ceiling is.
sublime2 is offline   Reply With Quote
Old 12-24-2012, 04:33 PM   #4
GBrackins's Avatar
Rewards Points: 2,108
are the stairs in the garage?
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 12-25-2012, 09:46 AM   #5
Rewards Points: 142
put the drywall up. when he leaves, take it down.
Fix'n it is offline   Reply With Quote
Old 12-26-2012, 10:30 AM   #6
AHH, SPANS!!!
Rewards Points: 1,166
^ the do it to make the inspector happy way. been there done that.
how about extra 3/4" foam board on the top side of the door cut to fit in between the steps and tacked to the top side of the plywood door or maybe light weight drywall if you can find it...
hand drive is offline   Reply With Quote
Old 12-26-2012, 10:44 PM   #7
Registered User
Rewards Points: 4,912
Be really easy to check after a fire to see wrong drywall (light-weight vs. Type-X) let the garage fire into your house attic. The attic spaces should be separated; if not at the access. Foamboard may require an ignition barrier, check locally. Keep up on your H.O. Insurance...
Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
AndyGump (12-26-2012)
Old 12-29-2012, 07:27 AM   #8
Rewards Points: 4,452
just replaced old rickety wood pull-down steps/folding ladder in garage w/alum pre-built which came faced w/paint ready 1/4" ply - never thought of having this work permitted OR inspected,,, garage ceiling has original 1/2" drywall ceiling - is it a new rqmt to cover stairway ply facing w/drywall 1/2" or 5/8 " ?
Old 12-31-2012, 11:16 PM   #9
Registered User
I'd check locally. Depends on who in charge is interpreting which code. 5/8 required with living space above ceiling. The attics may/not be connected. Sometimes a garage common truss is backed/drywalled in the attic to limit the amount/cost of drywall required on walls/ceiling with attached garage. Atlanta is under the IBC; http://www.reedconstructiondata.com/...codes/georgia/
A lot harder to find than in the IRC; http://publicecodes.citation.com/ico...2009/index.htm
Gary
Attic insulation suggestions? iwfur25 Insulation 1 07-09-2012 12:50 PM
Ideas for retrofitting baffles/insulation in vaulted ceiling of built out attic room rachelsue20 Insulation 5 04-28-2012 08:49 PM
Attic stairs Cliffrock Carpentry 7 09-16-2011 07:19 PM
Attic fan options. P550 Electrical 6 08-22-2010 01:30 PM
wiring code w.r.t. NEW folding stairs in garage attic fredsterl Electrical 4 09-26-2009 12:05 AM
