Old 04-08-2010, 02:10 PM   #1
Attic Project Advice Needed
Here is the scoop. I live in a 1907 home with an walk up attic. I just finished framing the attic. I used to have a brick chimney going through my roof (for boiler, there is NO fireplace in the house). The chimney leaked like crazy cause of deterioration. A contracter came out, removed it, put in a metal stack and new liner all the way to my basement.
Fast foward back to my attic project.
I removed the brick from under the roof line since it was in pretty bad shape, leaving the flex liner exposed. I built the knee wall and now the flex line is about 3 inches from the bottom plate of the knee wall. I'm worried about heat being so close to the wood. when i turn my heat on full blast, the flex line gets warm, but I can still touch it, but after a few seconds i have to pull my hand away from heat. is there some other type of barrier i can add.
would putting cement board on the back side of the knee wall facing the liner work?
thanks in advance.
StephenLevi is offline   Reply With Quote
Old 04-08-2010, 02:39 PM   #2
Moderator
kwikfishron's Avatar
Sure would.
kwikfishron is online now   Reply With Quote
Old 04-08-2010, 03:35 PM   #3
I'll do that then. It might get pretty close to liner (like inch away) but i dont think it would generate enough heat to cause a fire.
Needed basement advice... gripp2020 HVAC 4 11-29-2009 12:43 AM
Switching from old Oil Heating system, advice needed captainobvious HVAC 2 09-29-2009 02:18 PM
Advice needed for Exterior Trim painting fordman289 Painting 2 07-16-2009 02:10 PM
Drywall Project - Any tips, advice? dabretty Drywall & Plaster 4 02-01-2009 11:21 AM
Forced air and radiant system advice needed jasoncave HVAC 1 01-06-2009 09:46 PM
