Attic Opening - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-25-2011, 05:51 PM   #1
Rewards Points: 16
Attic Opening
Hi everyone,
I am covering the attic opening in my garage ceiling. Two questions please:
What amount of length should I add for the 45 degree angles ?
Also,how do i measure or cut to get enough trim to extend past the opening to hold the drywall.
Many Thanks and Merry Christmas!
Mark
Mark76 is offline   Reply With Quote
Old 12-25-2011, 06:10 PM   #2
Rewards Points: 14,306
For a simple first time DIY way to do it is to mark two lines on the back side of the trim 1/2" in from the edge of a piece of casing that's cut been precut 6" longer then the opening. tack two finish nails at the marks. Now hold the piece up and set the nails againt the opening, and make a mark on each end on the sheetrock, do it again for all sides. Now you have the lines to measure for length.
Old 12-25-2011, 06:12 PM   #3
Rewards Points: 16
2x4s
Old 12-25-2011, 06:14 PM   #4
DIY staff
Rewards Points: 7,174
You will be happiest if you use a little wider trim than the usual--I like 2 1/2"
Take your trim miter measurements from the inside of the miter--\______
------------------------------------------------------------Here-------------
Measure the opening--deduct the over hang X2--I like 3/4"--so 3/4 x 2 =1 1/2"
Make two of those--do the same for the other side---nail the corners of the frame together--
Lift the frame to the hole--center it--and nail it home---
Attic Insulation tim1218 Insulation 4 09-07-2011 10:18 AM
Attic project - Would like opinions whataboutj Insulation 6 06-29-2011 03:07 PM
Attic venting questions lemmy Roofing/Siding 36 05-28-2011 08:14 PM
Attic insulation over the cavity above the stairs jkocher Building & Construction 5 10-15-2010 09:03 AM
Powered Attic Fan question spup345 Roofing/Siding 9 06-30-2008 08:10 PM
