Attic Knee Walls - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-26-2009, 11:04 AM   #1
Rewards Points: 77
attic knee walls
Are there any stipulations/requirments as to moving or placement of an attic knee wall. I am planning on moving the current knee wall back to gain more floor space but first want to make sure there is not any things to take into consideration. Most of my research I only find topics regarding sheathing on the attic side of the wall. Nothing about structure or placement of the wall. Look to see what others think.
gregt848 is offline   Reply With Quote
Old 09-26-2009, 12:10 PM   #2
Registered User
Rewards Points: 526
Is there a bearing wall below the current knee-wall? What is the span of the rafters above, horizontally?What size rafters? Where are the collar ties, and how often? A few pictures would help....
Be safe, Gary
Old 09-27-2009, 11:07 AM   #3
Rewards Points: 162
Many times, attic knee walls are load bearing. You need to verify this before performing any modifications. One easy way is to look at your roof rafter framing. If the rafters are cut and bear on the wall, it's load bearing. You might also see an overlap with the rafters bearing on the knee wall at this point which would also suggest that it's load bearing. A picture here would be worth a 1000 words.
Some advice you receive on the internet can be worth exactly what you paid for it - be careful.
stubborn1 is offline   Reply With Quote
Insulation of interior walls around fire place ODD Calmeier Building & Construction 5 01-31-2010 05:59 PM
Solar Attic Fan? jazzscreamer Green Home Improvement 4 10-15-2009 12:16 AM
Need help with very ugly basement walls GrandmaStormy Remodeling 5 03-05-2009 02:43 PM
Attic Fan AND Whole House Fan PapaGnome HVAC 6 02-15-2009 02:28 PM
