Attic Knee Wall Insulation Improvments - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-07-2007, 10:46 AM   #1
Rewards Points: 12
Question
attic knee wall insulation improvments
I was told I should add some sheathing to the knee wall in my attic crawl space. The Insulation already has a vapor barrier. How would adding sheathing help? what would I use. wood? ridged foam? tyvek house wrap?
truebaca is offline   Reply With Quote
Old 07-07-2007, 11:04 AM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Your crawl space area, in an attic, is part of the "air flow chamber" that allows cold air or hot moist air to flow out of your home's attic. Outside air enters in from soffit vents and travels up and out through the ridge vent. Because of this, you have free movement of unconditioned air (unheated, moist, hot or cold air-movement), that you want to "seal off" from any "conditioned" (finished off) living area and it's insulation that protects that area.
So, the area you want to seal up, is located on the other side of that knee wall.
The best way to "seal" the backside of that knee wall (facing the crawl space) is to use rigid foam board and "spray foam" at any of the foam-board seams or transition points.
See this link, it explains everything along with great illustrations:
http://www.ibacos.com/pubs/FactSheet-KneeWalls.pdf
- Build Well -
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 09:20 AM
Built-in cabinets/shelves in bonus-room knee wall flamtap Remodeling 2 10-26-2009 10:14 AM
Running coax from attic to room below, via exterior wall? curls00 Electrical 13 08-15-2007 03:18 PM
Proper Attic Insulation reikiray Roofing/Siding 5 08-04-2007 11:59 AM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
