Attic Insulation And Ventilation - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-23-2011, 12:29 AM   #1
Attic insulation and ventilation
I'm fixing up an old garage to make it into a building for all of my aquariums. It will be very warm and humid in the building. I live in eastern Washington state. Not seattle (think Idaho or Montana climate). My question is what should I do to the attic? Im assuming I need a vapor barrier on the ceiling. What kind of insulation is best? How much and what kind of attic ventilation will I need. I plan to run a dehumidifier in the building but this space will be kept constantly at 72-75 degrees. Right now there is no ceiling, no insulation, no soffets or vents of any kind so I am starting from scratch and want to do it right. Thanks
Killa is offline   Reply With Quote
Old 10-23-2011, 02:18 AM   #2
Rewards Points: 1,092
First off, air seal like a madman; every conceivable crack or opening needs to be caulked, foamed, taped, whatever. Google the airtight drywall approach, too (ADA). Blow cellulose into the attic, as deep as you can afford or the sheet rock can support (depends on your spans). As for the vapor barrier, my gut says to avoid it, but that may be one for people who deal w/ high humidity inside, like pools, etc. Ventilation will surely help. I believe the rule for ventilation is 1 sf for every 100 to 150 sf of attic. Have plenty of ventilation, and keep the soffit vents close to the walls to minimize wind washing. Make sure you have at least 2" of air over the insulation near the eaves. If you pack the insulation in tight to the ceiling, you will be inviting icing, etc. If you just can not afford all the cellulose, use fiberglass batts (yuk!) and cover them w/ 3 or 4" of cellulose to prevent them from "leaking".
Old 10-23-2011, 01:03 PM   #3
Residential Designer
AndyGump's Avatar
Rewards Points: 664
Send a message via Skype™ to AndyGump
I think you need to be more concerned with venting the room itself.
You are going to need a constant source of fresh air entering and taking out the humid air, venting this into the attic would not be a good idea either.
Andy.
AndyGump is offline   Reply With Quote
Air sealing, ventilation, and attic insulation project-need advice Badfish740 General DIY Discussions 4 06-01-2011 07:48 AM
Recently Topped Up Attic with Blown Insulation...Now I have Frost/Condensation earthad1 Building & Construction 81 02-18-2011 01:42 PM
Insulation, Ventilation in Cape Cod Side Attic Get'n er done Building & Construction 10 12-03-2010 12:38 AM
Adding insulation and storage to Cape Cod Side Attic turin39789 General DIY Discussions 5 11-08-2010 11:50 AM
Finished attic insulation and ventilation issues diyfreak Roofing/Siding 1 10-08-2008 12:01 AM
