Attic Insulation Question - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-10-2009, 09:50 PM   #1
Attic Insulation question
I am converting my attic into a master bed. I am about to run my ventilation channels in my 2X6 rafters. I have 3 skylights about 3' from my knee wall. How do I get ventilation from soffit to ridgevent with the skylight in the bay? Also, should I overlap the channels or leave a space between each one. If space, how much?
Vermont1 is offline   Reply With Quote
Old 02-11-2009, 05:54 AM   #2
Rewards Points: 5,336
You don't get ventilation in the skylight bays.
I just butt the ends on the baffles.
Ron
Old 02-11-2009, 01:01 PM   #3
I assume this is for a cathedral ceiling. If you live in Vermont you will never get enough insulation into a 2 x 6. I would recommend going above code to prvvent ice dams to R40 or R50
I think the Dept of Energy recommends drilling holes at the top of the rafters to allow air to flow from one channel to the next around skylights. Exactly how to attach the air channels is some custom work. The air channels need ~ a 2" gap between each piece of styrofoam. THe styrofoam web site shows it.
PerpetuallyRepairing is offline   Reply With Quote
Old 02-12-2009, 09:58 PM   #4
I actually live in MA. This is a Cape Cod second floor. I am putting R21 (5 1/2") in the bays and 1" Rmax before sheet rock. This should give me approx R28. Across the top I am putting R30.
Recently Topped Up Attic with Blown Insulation...Now I have Frost/Condensation earthad1 Building & Construction 81 02-18-2011 01:42 PM
Faced or Unfaced Insulation in Attic??? capenpeck Building & Construction 13 11-06-2009 08:23 AM
Remove old insulation in attic? powerman4160 Building & Construction 10 01-30-2009 05:12 PM
Attic moisture Carstonio Roofing/Siding 14 01-29-2009 12:35 PM
attic ventilation chutes question MadisonMan Building & Construction 1 11-20-2008 11:52 PM
