Okay, the pics are part of a finished attic, behind the knee wall. Looking for suggestions on what I should do to insulate it. I am not seeing moisture issues. The cellulose is only about 5 inches. The silver you see is fiberglass in bags, silver on one side, brown paper on the other side, R11. The top and bottom show the side wall does not have insulation, is there a reason for this? The knee walls do not have any insulation. The duct work, for a second furnace, is only insulated about half the distance with fiberglass and plastic wrap.
Current thoughts, first looking for leaks, put in durovent attic vents, insulation over that. Was thinking about adding some insulation to the knee walls. For the duct work seal joints then wrap with insulation the foil/fiberglass stuff they sell. I've read some of the other threads, I'm looking more for any spoilers or oddities that you guys might see.
