Old 11-01-2009, 07:25 PM   #1
Default Attic insulation: clean before?
My smallish attic has 3.5 inch foil-faced batts between the joists. Some more insulation would obviously be a good idea and I plan to add R30 unfaced batts which are often available at Lowe's for 30 cents/sf (I'm in the Pacific Northwest). There is conduit and romex running here and there (which I don't imagine I'll need to access in the future) and the previous owner has used all sorts of odd bits of plywood to basically put a partial floor in above the joists (approx. 40% of the space).
Would it be okay to just lay the new batts down over the top of the plywood? Or would it be better to remove what I don't need?
Gibbyplease is offline   Reply With Quote
Old 11-01-2009, 09:22 PM   #2
ccarlisle's Avatar
The foil on the batts acts as a vapour retarder, which in you area should be on the outside of the insulation. You risk wetting the new insulation...
ccarlisle is online now   Reply With Quote
Old 11-01-2009, 11:13 PM   #3
Not sure I follow.
The foil is face down against the lath & stucco ceiling. Any additional fiberglass would just thicken the batts and all would continue to dry to the outside, under the ventilated roof.
Unless what you're saying is that the foil should be removed entirely and replaced with a lower-perm barrier, i.e. kraft paper?
Old 11-02-2009, 08:07 AM   #4
ccarlisle's Avatar
Oh, face-down is it? Well then OK, you can place new unfaced batts over that in the opposite direction from the frst layer.
Sorry, I just thought they were face-up...
Old 11-02-2009, 08:37 AM   #5
gravity always wins
Regarding the plywood. Ideally, you should remove it. You don't want any air gaps between the original insualtion and the new. And don't insulate tight against the underside of the roof along the eaves. Allow about and inch and a half air space below the roof deck.
Old 11-02-2009, 08:41 AM   #6
ccarlisle's Avatar
yeah, good point...the plywood doesn't serve any purpose apart form preventing you from going through the ceiling below. Useful, but not required in your project.
More On This Topic
Hi! My name is Joshua Lindsey with CFM Building Science Solutions. On behalf of Expert Village, we are doing a frame walk and insulation inspection on this home. The next one that we are going to cover on this list is going to be the air barrier and all... Read More »
Hi! My name is Joshua Lindsey with CFM Building Science Solutions. On behalf of Expert Village, we are doing a frame walk and insulation inspection on this home. The next thing on our list is going to be the garage band joist air barrier. What that is... Read More »
Your sunroom is could be sitting empty most of the time, because it's too hot in the summer and too cold in the winter. Your sunroom can become a place for year-round enjoyment with a few easy steps. Imagine it as a haven--a place to sit and read, eat or... Read More »
If you are at a loss as to what to do with your keepsakes, handed down furniture, year books, children’s toys or holiday ornaments, you should look up and consider your attic. Homes used to be made with stairs that went to the attic. Here children... Read More »
Hi! My name is Joshua Lindsey with CFM Building Science Solutions. On behalf of Expert Village, we are doing a frame walk and insulation inspection on this home. Alright I want to show you this new wall right here. This new wall has all our sides we are... Read More »
Idea for attic insulation baffles. What are your thoughts? Ininkus Building & Construction 8 02-26-2009 02:46 PM
Adding attic insulation and cutting soffits a DIY job? drh Roofing 15 12-31-2007 09:47 PM
attic insulation question dderolph Building & Construction 10 11-03-2007 07:21 PM
So, HOW to put down insulation in the attic? SarahTZ Roofing 11 03-08-2007 11:33 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
