Attic Insulation - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-19-2010, 09:06 AM   #1
Question
Attic Insulation
I have a split level home and the insulation is pretty old. and in the summer the upper level of the house is really hot. i replaced the upper have with R-19 insulation, but now the house seems kind of cold. when I replaced the insulation I put it close to the rafters, do they need to be pushed up against the underside of the roof? oh and I didn't install any rafter vents. Thanks
solblanca23 is offline   Reply With Quote
Old 11-19-2010, 10:25 AM   #2
Rewards Points: 590
The standard for your zone is R38 in the attic. However, this is difficult to accomplish between the rafters.
Is the attic living space? If not, you should be insulating in the floor. The current strategy is to blow cellulose into the floor. You normally get to borrow the machine for free when you buy bags of it. If there's living space, the best way is to install a flat ceiling and knee walls so that you have more room to insulate.
There's a lot to be said about this, so I'll sit back and see what the real experts have to say :-)
operagost is offline   Reply With Quote
Old 11-19-2010, 11:09 AM   #3
ccarlisle's Avatar
"Feeling comfortable" in your home has as much to do with air movement as it does with insulation level or type i.e if you haven't air sealed your home, and find you have cold zones and drafts, the insulation type won't make one bit of difference to your comfort level.
You might also need a vapour retarder - or some examination of what you already have before deciding on R13, R19 or whatever - level of insulation you should have for your climate.
“The average American woman is about 25 pounds heavier than she was in 1960...Recognizing obesity as a disease will help change the way the medical community tackles this complex issue that affects approximately 1 in 3 Americans,”
ccarlisle is offline   Reply With Quote
Old 11-19-2010, 01:30 PM   #4
do I need to install a fan on the gable vents?
Old 11-19-2010, 03:09 PM   #5
ccarlisle's Avatar
You may. Or may not, depends...there's no way I or anyone else here could tell you that.
There's no one sure-fire solution to what is a whole-house problem; each component affects the nhome-comfort level and it all comes down to fine-tuning. But your attic ventilation is only part of it and whether or not you need a fan up there depends on what problems you have now. Let's not get too far ahead of ourselves.
There are just too many variables to conduct an investigation on-line, I'm afraid.
Attic Insulation gruntman Roofing/Siding 12 12-04-2010 09:01 PM
Remove old attic insulation and critter mess? merlanvp Building & Construction 6 07-27-2010 04:36 PM
Attic insulation and soffit venting zacker Building & Construction 1 07-15-2010 10:17 PM
Finishing Attic, insulation question pjgsteelers Remodeling 1 07-13-2010 01:59 PM
adding attic insulation to existing insulation strouddljs General DIY Discussions 4 11-09-2009 05:06 PM
