Attic Insulation - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-14-2010, 01:33 PM   #1
Attic Insulation
I just bought this 50 years old multi unit house (side by side). The small apartment has a big attic space that I want to convert to a heated study room or a bedroom.
There is no vent in the attic execpt the two big windows on each side.
The floor is filled with selulose, and half finished with pine woods.
The ceiling is insulated R30. All sides (front, back, sides) of the insulation R30 rolls are covered with aluminum foil. I remember somebody saying that it makes no good against condensation.
The walls had nothing but I insulated with R13. The picture is taken before R13 insulation.
Before I start doing any drywall and kneewalls, what are my options to do insulation job the right way? Should I replace the ceiling and floor insulation? Should I install suffit vents, ceiling or wall vents? I appreciate all recommendations.
Are these DIY jobs?
expertie is offline   Reply With Quote
Old 11-14-2010, 05:30 PM   #2
Registered User
Rewards Points: 5,216
This will get you started while you tell us where you are located and the floor joist size and span to see if it's feasible before getting your permit.
http://docs.google.com/viewer?a=v&q=...1txlzU01V4JQIg
Gary
Attic Insulation gruntman Roofing/Siding 12 12-04-2010 10:01 PM
Remove old attic insulation and critter mess? merlanvp Building & Construction 6 07-27-2010 05:36 PM
Attic insulation and soffit venting zacker Building & Construction 1 07-15-2010 11:17 PM
Finishing Attic, insulation question pjgsteelers Remodeling 1 07-13-2010 02:59 PM
adding attic insulation to existing insulation strouddljs General DIY Discussions 4 11-09-2009 06:06 PM
