Attic Insulation - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-19-2010, 10:14 AM   #1
Attic insulation
Do I need blown-in fiberglass on the attic floor if I foam the roof deck?
Mrdaddy is offline   Reply With Quote
Old 10-21-2010, 10:17 PM   #2
Registered User
Rewards Points: 4,912
No. http://www.buildingscience.com/docum...r-all-climates
Gary
Old 10-22-2010, 12:44 AM   #3
Rewards Points: 956
thats what i am doing with mine too. spray foam the deck. no venting!
federer is offline   Reply With Quote
Old 10-23-2010, 02:27 AM   #4
Rewards Points: 1,092
I understand that cc spray foam is getting more popular against roof sheathing, but I always worry about a tiny little leak somewhere. If the foam is several inches thick, I don't see your sheathing drying, but I do see it rotting. Maybe the roofing material is moisture permeable enough (depends on what you use), but I'd at least make sure my sheathing could breathe to the outside if I foamed it inside. If you do not spray the roof, then I'd suggest you look at blowing in cellulose instead of fiberglass.
Attic Insulation gruntman Roofing/Siding 12 12-04-2010 10:01 PM
Remove old attic insulation and critter mess? merlanvp Building & Construction 6 07-27-2010 05:36 PM
Attic insulation and soffit venting zacker Building & Construction 1 07-15-2010 11:17 PM
Finishing Attic, insulation question pjgsteelers Remodeling 1 07-13-2010 02:59 PM
adding attic insulation to existing insulation strouddljs General DIY Discussions 4 11-09-2009 06:06 PM
