Attic Insulation - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-21-2008, 10:38 AM   #1
attic insulation
I have some very cold spots in the upstairs, especially closets in three rooms. Before we bought the house, the former owners had central air installed. I think they moved or removed insulation to place equipment and run duct lines. My guess is they never replaced the insulation properly. Two of the closets back up to dormer space and hard to get to. The attic is a crawl space with not much room to work. There is so much equipment and duct work up there, I don't know if it possible to place conventional insulation. Are there any products that anyone might suggest? Thanks.
david187 is offline   Reply With Quote
Old 01-21-2008, 11:01 AM   #2
HD sells blow-in insulation and also will loan you the blower machine if you buy enough. You fill the machine and just stand where you can with the hose and out blows the insulation.
pesphoto is offline   Reply With Quote
Old 01-23-2008, 10:52 PM   #3
I agree with the previous poster. There are two kinds of loose-fill insulation: fiberglass and cellulose.
The cellulose is what I think Home Depot sells and it's usually the least expensive of the two. The operation runs a lot easier with two men working it. One to feed the hopper and one to blow the insulation in. You don't want to have to climb in and out of the attic each time the hopper empties.
You might consider upgrading your entire attic to R30 while your up there.
You'll recover the cost over the time you own your home.
Randell Tarin is offline   Reply With Quote
Old 01-24-2008, 07:08 AM   #4
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Your assumptions, I'm sure are correct. We see this all the time, espeically on commercial and multi-resident construction (after the utilities are run in the attics).
You can also purchase hard-packed cellulose, that you break-up and loosen yourself and fill by hand = if you have smaller areas to "top-off" or add to.
- Build Well -
Old 01-24-2008, 08:19 AM   #5
I had to buy 20 bags of the loose insulation in order to get the blower rental for free. My initial cost was going to be about $180. When my frined and i finished we had 7 unused bags of insulation. I called HD and they offered to refund my money and still not charge me for the blower. So in the end it only cost me around $125 to fully insulate my attic as well as a couple walls.
Well worth it. My wife says it feels much warmer, especially on the 2nd floor of the house. So..if she's happy...........Im happy!
Old 01-24-2008, 09:14 AM   #6
attic insulation
Thanks for the advice. How careful do I have to be spraying around the a/c unit, condeser line, overflow pipe, etc? Thanks.
Old 01-24-2008, 09:28 AM   #7
Read up or get a manual with the product..
Yes care is needed... depends on your conditions..
Don't fill ac unit condensate overflow pan... needs to breath at soffit (proper vent).. close penatrations at vent pipes... don't cover lighting if fixture is not rated.. etc.
Big Bob is offline   Reply With Quote
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
Insulation over Attic Walkway BigJimmy Building & Construction 4 06-23-2008 02:13 AM
Attic Insulation jim_arnau Building & Construction 13 11-07-2007 08:59 AM
attic insulation question dderolph Building & Construction 10 11-03-2007 05:21 PM
Proper Attic Insulation reikiray Roofing/Siding 5 08-04-2007 10:59 AM
