Old 07-21-2011, 01:50 PM   #1
Attic Hatches
I am trying to locate an access hatch for my attic.
I need one that fits 14" between joists (16" OC?) - the only one I have located is the "Sealin' Hatch" - but i am located in Canada and have not yet found a retailer.
Anyone in Canada found a source for this item?
GuyBooth is offline   Reply With Quote
Old 07-21-2011, 02:08 PM   #2
Architectural Designer
AGWhitehouse's Avatar
Attic Hatches
Wow that's a small hatch...get a stereotypical repair man and he'll get stuck...
Is there a reason you don't want to re-frame the small area to get a hatch in there that will accomodate a human w/ toolbag?
Life's too short...so enjoy it!
AGWhitehouse is offline   Reply With Quote
Old 07-21-2011, 10:23 PM   #3
Attic Hatches
Main reason at this time - I'm not sure how to do the reframing myself and maintain the integrity of the joists. Tracking down someone with the right skills might be a challenge right now but I haven't ruled it out.
The 14" between joists is not totally impossible - but the hatch I currently have is 14" in BOTH directions. That IS tight! Hence my question - the hatch model I'm looking for is 22.5" wide.
Old 07-21-2011, 10:30 PM   #4
Average Joe/ex-Navy IC3
gregzoll's Avatar
Attic Hatches
That is about how big the scuttle hatch is into my attic. Personally I would like it a little bigger, but since it sits in the pantry, I am leaving it as is.
Old 07-21-2011, 11:04 PM   #5
Attic Hatches
I've used plastic bubble skylights to create a roof hatch cover. Build a small frame to which the skylight is attached. Flash the frame-install the skylight to the frame. Build a roof curb-flash it. Use spring-loaded buckles to attach the skylight/frame assembly to the curb, using a 1-1/2" x 1/4" foam seal.
EricL503 is offline   Reply With Quote
Attic project - Would like opinions whataboutj Insulation 6 06-29-2011 04:07 PM
Raccoons in the attic electricpete Pest Control 17 05-12-2011 05:02 AM
Ventilating attic with two roofs senorbungle Building & Construction 2 01-09-2011 05:17 PM
Attic fan options P550 Roofing 1 08-22-2010 01:47 PM
Attic Fan AND Whole House Fan PapaGnome HVAC 6 02-15-2009 03:28 PM
