Attic Flooring - OSB Or Plywood - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-18-2010, 04:27 PM   #1
Attic flooring advice
Hello,
The attic in my 2 story house is built using 2x8 joists and fibreglass insulation. I'm having an additional 6" of blown-in cellulose insulation installed to improve the energy efficiency.
I would like to use the attic space for additional storage. I'm planning to install 2x6 rafters on top of the existing 2x8's (24" apart) and then planning to install 1/2" plywood or OSB. Even though I don't need the entire 40'x40' space in the attic, I'm planning to install flooring on all of it - except for the boiler and ductwork.
I would appreciate any comments on the approach. Would the additional weight of 2x6's and plywood/OSB impact the structural integrity of the house?
Thanks for your help/comments.
Best.
tariqk is offline   Reply With Quote
Old 10-19-2010, 07:58 PM   #2
1/2" plywood?
Two feet on center?
The boilers in the attic?
Flooring?
II Weeks is offline   Reply With Quote
Old 10-19-2010, 08:03 PM   #3
jlhaslip's Avatar
Rewards Points: 924
You would need at least 3/4 inch material to avoid it being springy.
Originally Posted by Bud Cline View Post
Go ahead and apply for a variance, those guys at City Hall can use a good laugh.
jlhaslip is online now   Reply With Quote
Old 10-19-2010, 08:52 PM   #4
STRUCTURAL
The additional weight of wood is not a concern, the real problem is the storage in the attic for which the existing and new added joists may not be sufficient. There isn't enough information to go by as to how the joists are supported and their span.
2' spacings, 1/2" plywood or OSB, all these are OK for light storage.
ENGINEER10 is offline   Reply With Quote
Old 10-20-2010, 09:15 AM   #5
Originally Posted by II Weeks View Post
1/2" plywood?
- Yes, I was planning to use 1/2" (or maybe 3/4" based on feedback) plywood or OSB.
Two feet on center?
- The existing joists are 16" apart. The new ones that I put are 24" apart since I only plan on storing light stuff like Christmas decorations and kid toys.
- My bad, its the air handler for the AC.
Flooring?
- just some planks.
Hope this clarifies.
Old 10-20-2010, 09:17 AM   #6
Thanks for your response(s). I'll plan to use 3/4" OSB or plywood and leave the spacing between 2x6" as 2'.
Thanks again.
Old 10-20-2010, 12:25 PM   #7
Registered User
Rewards Points: 5,204
For light storage in the attic, I would use 1/2" plywood, cut into 12" rips spaced 1/2" apart. This will let any heat/moisture from the conditioned space below to vent without condensing on the bottom side of the plywood. The framing would sit on 1x4 secured perpendicular to the joists over the bearing points to keep the new joists free-spanning over the bearing wall below. Use a 1x4 on the ends of the new as a rim joist to prevent lateral displacement (tipping over) held flush with the top edge. No OSB as it cannot handle moisture well and mold loves it. Figure the 2x6's at 24"o.c., to check your spans by entering them under "ceiling joists w. 20# load" here: http://www.awc.org/calculators/span/...orizontal+Span
Gary
Fixing a screwup - stain on oak plywood brich Carpentry 9 05-14-2010 12:09 AM
Allure flooring and prep work bstreyle Flooring 1 04-12-2010 04:43 PM
Attic joist cross beams & moving them Fox Building & Construction 11 04-02-2010 09:48 PM
OSB flooring for attic storage? echase Building & Construction 1 03-25-2010 07:00 AM
Finished attic humidity? kcrossley2 HVAC 2 08-11-2009 06:06 AM
