Attic Floor Thickness? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-03-2010, 01:01 PM   #1
Attic floor thickness?
I want to put some plywood in the attic above my garage to store some seasonal items. The 2 x 4 trusses are either 20" or 24" on center. I can't recall which. What thickness plywood should I lay down? Will OSB work, or do I need to use plywood?
Thanks!
mopowers is offline   Reply With Quote
Old 08-03-2010, 01:03 PM   #2
Electrician
Proby's Avatar
Are you going to be walking/crawling on this plywood, or just laying seasonal items on it from the access hole?
Anything fun is either illegal, immoral, or fattening.
Proby is offline   Reply With Quote
Old 08-03-2010, 01:09 PM   #3
I'll be walking around. I went up there to install a bunch of outlets and lights in the garage. Walking on the joists got a little old. I won't be going up there very much anymore. I just want to be able to put some items up there and move around a little.
Old 08-03-2010, 02:42 PM   #4
I'd put 1x shelving grade boards up there with gaps between. They're stiffer. You just need enough to walk on.
If you use plywood then fasten it to every rafter to give some stiffness to the surface. Here's a link from DH
http://g-lumber.com/pdf/APA_Plywood_...cification.pdf
For the dead load, figure your added wood at 35 # per cu. ft.
Old 08-03-2010, 03:59 PM   #5
Rewards Points: 1,910
Very few attic trusses are designed for using the attic for storage. Keep only a few light things up there at most.
Old 08-03-2010, 04:35 PM   #6
Registered User
Rewards Points: 5,516
http://www.tricountytruss.com/CodeChanges.aspx
Be safe, Gary
Raccoons in the attic electricpete Pest Control 17 05-12-2011 04:02 AM
Recently Topped Up Attic with Blown Insulation...Now I have Frost/Condensation earthad1 Building & Construction 81 02-18-2011 12:42 PM
venting and moisture in attic Alto Roofing/Siding 3 07-29-2010 09:31 PM
Finished attic humidity? kcrossley2 HVAC 2 08-11-2009 05:06 AM
Attic Fan AND Whole House Fan PapaGnome HVAC 6 02-15-2009 02:28 PM
