Attic Floor Sheathing - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-29-2010, 05:48 PM   #1
Rewards Points: 358
attic floor sheathing
My attic has a fold down stair case leading up and have a raised storage area that right now is just covered VERY thick cardboard. The joists are at 12" on center on this platform. I would like to sheath it so I can easily store things on it without worrying about it breaking this cardboard.
I was thinking maybe a 1/4" plywood would work great. Any thoughts? It will just be junk storage for holiday decorations and such.
Can a average size person stand on a 1/4" plywood safely? I have no problem using 1/2", but saving money is always a plus
I was thinking about just using a drywall screws at say 12" o.c. to hold down this flooring so I could easily remove it if necessary.
Thoughts?
Thanks!
cbzdel is offline   Reply With Quote
Old 07-29-2010, 08:49 PM   #2
Rewards Points: 5,336
I would use a minimum thickness of 5/8", though you could get away with 1/2".
Ron
Old 07-29-2010, 11:33 PM   #3
Registered User
Rewards Points: 526
I would rip the plywood into 12" widths, spaced about an 1" apart to let the moisture rise into the attic to be removed by your venting system rather than deposited on the underside of the plywood causing mold. Breath.....
Be safe, Gary
Raccoons in the attic electricpete Pest Control 17 05-12-2011 04:02 AM
Recently Topped Up Attic with Blown Insulation...Now I have Frost/Condensation earthad1 Building & Construction 81 02-18-2011 12:42 PM
venting and moisture in attic Alto Roofing/Siding 3 07-29-2010 09:31 PM
Finished attic humidity? kcrossley2 HVAC 2 08-11-2009 05:06 AM
Attic Fan AND Whole House Fan PapaGnome HVAC 6 02-15-2009 02:28 PM
