Attic Conversion Questions... - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-25-2011, 03:36 PM   #1
Hi Everyone,
I am working on converting my attic into living space and I have a few questions.
1. The roof was built with 2x4's 24" oc. I am thinking of sistering 2x6's to these to add some additional support. Anything more than 2x6 would compromise head room.
Would the 2x6's even be needed? Or, would they actually give enough support that would make it worth sistering them? What do you think?
2. Also, the joists that make up the attic floor are 2x6. Will this be sufficient to hold the additional weight that will be upstairs?
SQuinn88 is offline   Reply With Quote
Old 11-25-2011, 03:41 PM   #2
Framing Contractor
Originally Posted by SQuinn88
Hi Everyone,
You need an architect or engineer to tell you. You will need permits and inspections to do this. Are you planing on doing this?
Joe Carola
Joe Carola is offline   Reply With Quote
Old 11-25-2011, 05:19 PM   #3
Rewards Points: 502
for the floor, it depends on the spans involved.
for the roof, you probably don't need a whole lot more strength, just enough to hold up the drywall and insulation. If it is bowed already, it probably needs some help. if not, it is probably fine. what do you plan on for insulation?
If you think you do need more strength, I'd probably put additional 2x4s horizontally under the current 2x4s, like an upside down T, as apposed to sistering in 2x6s. another option would be to sheet it with plywood. that will add strength to the roof without cutting into your probably minimal height that is there.
forresth is offline   Reply With Quote
Old 11-25-2011, 11:06 PM   #4
Rewards Points: 5,336
As Joe said, you will need professional guidance on this. Floor structure aside, there's a headroom issue, windows and egress.
Sometimes an attic is just that.
Post some photos of the area you want to convert.
Ron
B. Franklin 1759
Old 11-26-2011, 12:30 AM   #5
JOATMON
ddawg16's Avatar
Rewards Points: 1,454
The other guys answered the questions.....
But let me stress.....even without engineering input....I can tell you that those 2x6's are not nearly enough support for any type of live or dead load. You can do a search for span tables....those 2x6's are only for a ceiling....and maybe one person working in the attic.
To give you an idea, my garage has an attic that is rated as a 'usable space'. The garage is 20x25....in the center I have a 7x16 PSL beam...on top of that I have 2x8 floor joists on 12" OC.
Your 2x6 ceiling joists on 16" OC are not even close enough.
Get an Engineer....otherwise, your attic living space is going to end up on the lower level.
Old 11-26-2011, 01:22 AM   #6
Residential Designer
AndyGump's Avatar
Rewards Points: 666
Send a message via Skype™ to AndyGump
Oh, you really do need to talk with a professional designer on this, then when you have a plan that will pass to the permit phase and you have the go-ahead from the Building Depart, start swinging that hammer.
Andy.
AndyGump is offline   Reply With Quote
Old 11-26-2011, 10:27 AM   #7
Rewards Points: 502
you don't need to hire a professional to look at span tables
Old 11-28-2011, 03:46 PM   #8
Span Calculator
Here's a freebie!
http://www.awc.org/calculators/span/...rcalcstyle.asp
granadaCoder is offline   Reply With Quote
Newbie questions on refinishing walkup attic with knee walls FileOpen Insulation 2 11-19-2011 11:31 PM
Forced hot air conversion questions. Tmb9862 HVAC 2 01-26-2011 07:57 PM
Frost in the Attic 295yards General DIY Discussions 13 12-07-2009 04:27 PM
Finished attic humidity? kcrossley2 HVAC 2 08-11-2009 05:06 AM
Attic Ventilation Questions AllGoNoShow Roofing/Siding 4 11-26-2006 12:02 PM
