Attic Buildout With Truss Reconfig HELP!!! - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-27-2008, 01:06 AM   #1
Lightbulb
Attic Buildout with Truss Reconfig HELP!!!
Ok, I had a shady contractor start an attic build out for me. my attic had 2x4 trusses on 24" center. The contractor put in a 2x6's nailed to the 2x4 in the roof, top brace. Additionaly a verticle knee wall support is resting on a 2 - 2x10 beam spanning between 2 load bearing walls. The flooring is 2x8's on 24" centers and 3/4" tongue and grove plywood. If you look at the pictues you will see the first 10 feet have been done and the remaining trusses need to be reinforce and cutout.
Attic Pictures with Comments
My concerns:
1. Is this a good method? Do I need additional bracing
2. Should I add more 2x6's in between the 24" in the roof, top and vertical support?
Any other advice and comments would be greatly appreciated.
Thanks,
g
AtticHelp is offline   Reply With Quote
Old 03-28-2008, 11:50 AM   #2
I am doing something similar, but I do not have trusses, just 2x4 rafters 16OC. An architect friend told me to go with 2x8's sistered to the 2x4 rafters and to nail 2x4 gussets like yours, but nail them on the 2x8s. I have not had a chance to ask him, but I would think the sistered 2x8s should go from the ridge board/peak down where it can sit on the wall/floor, not just part of the way like in your pics. One ? I do have is this is true about bringing the new rafters down as far possible, does one cut it to fit into the opening just under the roof where the old 2x4 sits on the wall or just as close as possible.
Sorry to hijack the thread
mn_homesteader is offline   Reply With Quote
Attic Smell from A/C - I'm at wit's end! cidsamuth HVAC 19 08-23-2016 05:36 AM
Gambrel Attic Roof Truss ETD66SS Carpentry 28 05-11-2009 02:36 PM
Gambrel Truss Dormer and Ladder Framing? fauer Carpentry 3 09-30-2007 07:36 PM
Want to build closet in attic. Need advise. mbrittb00 Building & Construction 1 11-14-2006 06:58 PM
Air duck from basement to the attic MageMinds HVAC 2 04-26-2006 12:41 AM
