Old 01-23-2010, 12:02 PM   #1
Attatching old concrete to new
Hello all:
I bought a repo cheap, one reason was foundation. Most of the house has a good footing and stemwall. The problem..........the addons were set on cinder blocks and now the two new additions are trying to pull away from the old house. I will have to pour new footing and stemwall under the house. I am afraid i will have pour it in four foot sections. Once I pour how do I attatche the pieces together?
bill333 is offline   Reply With Quote
Old 01-23-2010, 12:25 PM   #2
joed's Avatar
Install rebar in the new concrete for connection to the next section.
Do not PM with questions that can be asked in a forum. I will not respond.
Old 01-23-2010, 02:18 PM   #3
& since you'll be placing new conc onto/against old, we'd coat the existing w/epoxy for a ' grout ' & paste to grout the ' new ' old conc,,, can you btw, install using a hop-skip method ? ? ?
itsreallyconc is offline   Reply With Quote
Old 01-24-2010, 09:09 AM   #4
Dowels, drill holes in existing walls put dowel rods into holes and secure them , run them over to the new footings , once you pour it's staying there.
SULTINI is offline   Reply With Quote
How To Keep Your Concrete Mixer Driver Happy Mort How To Guides 36 08-05-2012 11:43 AM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 10:49 AM
how to fill the gaps between concrete blocks? micapavlov Building & Construction 4 01-03-2010 05:53 PM
Help!: 4" concrete over 2' dirt over 7/8 wood planking! agent99 Flooring 4 04-28-2009 09:21 AM
new concrete floor next to old concrete floor mattroos Building & Construction 10 08-28-2007 02:32 PM
