Attaching Wood Walls To Concrete Slab - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-17-2011, 11:25 AM   #1
Carpenter Wannabee
Attaching wood walls to concrete slab
I am building a garage and want to make sure I protect my wooden walls sufficiently from the concrete. I am using pressure treated lumber for my bottom plate but wanted to know if it was necessary to use any additional barrier between the concrete and the pressure treated lumber? Also, when I apply the sheathing, which I was planning to have extend beside the slab, is it necessary to use pressure treated plywood for that?
Ron55 is offline   Reply With Quote
Old 12-17-2011, 11:47 AM   #2
firehawkmph's Avatar
Rewards Points: 1,884
Ron,
depends a lot on where you are located. Update your profile and you'll get better responses. I use a foam sill sealer between the treated plate and concrete slab or blockwork. Codes around here require bottom of framing to be at least 8" above finish grade. If you meet that, cdx plywood should be fine for sheathing.
Mike Hawkins
firehawkmph is offline   Reply With Quote
The Following User Says Thank You to firehawkmph For This Useful Post:
Ron55 (12-17-2011)
Old 12-17-2011, 12:54 PM   #3
concretemasonry's Avatar
Rewards Points: 2,608
I hope you plan to use the appropriate anchor bolts to keep the garage held down and in the same county. You don't have to use special bolt materials for the embedded portion, but any fastener in treated wood has to be made for that purpose to prevent the preservatives from destroying it. - That can happen in a few short years.
Dick
concretemasonry is offline   Reply With Quote
The Following User Says Thank You to concretemasonry For This Useful Post:
Ron55 (12-17-2011)
Old 12-17-2011, 01:50 PM   #4
Facilities Maintenance
To nail wood to concrete, you can always get a HILTI Powder Actuated Tool, with apprpriate fasteners that come with the tool, and nail the wood into the concrete without problems.
BigGuy01 is offline   Reply With Quote
Old 12-17-2011, 02:06 PM   #5
Tileguy
Bud Cline's Avatar
Rewards Points: 558
...and Building Codes approve that method for securing a structure to a slab ???
XXX
Old 12-17-2011, 10:04 PM   #6
Rewards Points: 1,092
I believe that an EPDM gasket between the concrete and the wood eliminates the need for PT wooded and associated hassles. Ask a local building inspector. I see that done here.
Old 12-17-2011, 11:37 PM   #7
Registered User
Rewards Points: 5,516
http://www.greenbuildingadvisor.com/...-building-code
If you are under the IRC;http://publicecodes.citation.com/ico...9_3_sec017.htm
http://publicecodes.citation.com/ico...004_par043.htm
As said, check locally.
Gary
Old 12-18-2011, 08:20 AM   #8
Rewards Points: 3,130
Not a chance! Perhaps some are misreading the initial post (I did at first). I thought he meant a partition wall, not the main walls of the garage. Totally different thing. Depending on local code, there should be some sort of anchors embedded in the slab.
The Following User Says Thank You to md2lgyk For This Useful Post:
Bud Cline (12-18-2011)
Old 12-18-2011, 10:51 AM   #9
Tileguy
Bud Cline's Avatar
Rewards Points: 558
There ya go!
XXX
Old 12-18-2011, 11:41 AM   #10
Rewards Points: 13,750
Foundation bolts are needed. Do yourself a favor and build stem walls not just a pored slab. Do a key word on "stem wall."
By the questions your asking it may be best to have someone that knows what there doing build this for you.
Old 12-18-2011, 01:09 PM   #11
As well as getting an experienced person to DESIGN and help build the whole deal, make sure you insulate under it if you are ever going to heat it: A minimum of 2" of rigid foam under the slab, and, if you are in a heating-dominated environment, under the footer, and in and out on the stem wall or edge beam (whatever you do there).
Old 12-18-2011, 07:08 PM   #12
Carpenter Wannabee
Guys, all I was asking about was the issue of the concrete touching the wood. I apologize for not making it clear that I was only talking about the exterior walls. I have anchor bolts in a monolithic slab. I appreciate the suggestion of the EPDM gasket which seems like a better way to keep it "green". I also apprciate the info regarding the use of cdx plywood when keeping the walls 8" above finish grade. Our local codes require the same 8" limitation. Thank you all for your input.
Installing 9mm bamboo over 9mm wood floor and concrete hellobritt Flooring 4 08-30-2011 09:35 PM
Repairing concrete slab in shower JohnRoss Building & Construction 0 08-08-2011 01:20 PM
Shower Base with Concrete Walls Matt Staben Tiling, ceramics, marble 4 07-07-2011 11:18 PM
Pouring Concrete Slab in a small rickety garage. RORO Building & Construction 0 10-19-2010 03:56 PM
Concrete slab weeps moisture dale h Flooring 2 04-30-2005 10:29 AM
