Attaching Wood Srtips To Concrete Wall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-20-2007, 08:30 AM   #1
Question
Attaching wood srtips to concrete wall
Hello All!
I was wondering what is the best way to attach 1x2 PT furrins strips to my poured concrete basement walls? I am using the furring strips along the stairs where it is not possible to frame out with 2x4s.
Last night I tried tapcons with predrilling th ewholes but it took forever and the tapcons did not get tight, they just spun like they where stripped out. Any ideas /suggestions?? Any help would be greatly apprecaited!!
DIY4EVER is offline   Reply With Quote
Old 07-20-2007, 08:48 AM   #2
Agent 000
SecretSquirrel's Avatar
If the Tapcons aren't working out for you then several concrete anchoring solutions here at this website.
Sounds like you're using a conventional drill to make your pilot holes. A hammer drill would make your life a lot easier.
Or you could rent a 22cal Ramset gun.
If you ain't making noise, you ain't doing anything <LOL>
SecretSquirrel is offline   Reply With Quote
Old 07-20-2007, 09:29 AM   #3
Mechanical Engineer
comp1911's Avatar
Rewards Points: 150
Pl400?
comp1911 is offline   Reply With Quote
Old 07-20-2007, 09:35 AM   #4
Question
S.S.--- I tried using my hammer actuated Ramset nailer with .22 caliber shots but that split the heck out of the wood. I am using a conventional drill, so I will try a hammer drill next.
Comp1911--- no idea what PI400 is. Can you elaborate?
Old 07-20-2007, 09:37 AM   #5
Mechanical Engineer
comp1911's Avatar
Rewards Points: 150
PL400 construction adhesive.
Old 07-20-2007, 09:55 AM   #6
RippySkippy's Avatar
...Ramset nailer with .22 caliber shots but that split the heck out of the wood.
Turn your stick of wood 90*, the grain might be working against you. You could always drill a small pilot hole in the furring strip...I like to use the ram set nails and adhesive...but I'm just anal.
RippySkippy is offline   Reply With Quote
Old 07-20-2007, 10:20 AM   #7
Is PL400 adhesive strong enough by itself to hold the strips to the concrete with 1/2" drywall hung on them?
Old 07-20-2007, 10:44 AM   #8
Once cured...sure. You want something to keep them in place while the glue cures.
Old 07-20-2007, 10:45 AM   #9
Mechanical Engineer
comp1911's Avatar
Rewards Points: 150
I don't know, I'd still want a few mechanical fasteners installed just to hold them while the adhesive sets up.
Old 07-21-2007, 09:14 PM   #10
Deplorable Electrician
MechanicalDVR's Avatar
Rewards Points: 81
PL400 will hold the strips and the rock to the strips as well with just screws on the edge joints. If you really want mechanical fasteners in the furring strips just bent nail studs with the PL400.
MechanicalDVR is offline   Reply With Quote
Old 07-21-2007, 09:43 PM   #11
yummy mummy's Avatar
Rewards Points: 1,016
I found that using a hammer drill for concrete is a must.
Also, make sure that you use the correct drill bit for the size of Tapcons that you are using, and I always try to make the hole a little longer.
And make sure you get all the concrete dust out of the hole, as that can interfere with the tapcon going all the way in.
Make sure you have a good drill bit for the tapcon. If you have a worn out one, you may strip the head. And drive it in slowly.
You may even have to finish putting the screw in by hand.
yummy mummy is offline   Reply With Quote
Old 07-21-2007, 10:10 PM   #12
how about T-nails and a concret nailer I have been useing this to attach 2x4 to my slab for a bottem plate and put one on the wrong line had on heck of a time getting it up again Just my thoughts though
clasact is offline   Reply With Quote
Best way to handle this - furring out concrete freeze wall J187 Building & Construction 10 05-14-2007 05:17 PM
Concrete cement wall leaks and paint BobFar Building & Construction 7 04-16-2007 05:22 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
Wood to Concrete without Drilling MattStata Carpentry 1 04-19-2006 04:16 PM
