Attaching Wood Posts To Top Of Existing Foundation Wall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-14-2011, 09:23 PM   #1
Rewards Points: 256
Attaching wood posts to top of existing foundation wall
I currently have a patio which is surrounded by a concrete foundation wall (approx 7" wide/thick), which supposedly goes down 42", below the frostline here in new England (need to verify that yet). I wish to build a pergola-type posted patio cover. I "assume" I can use this wall as a foundation for my pergola posts, but am unsure how to attach the posts as per code. I am certain there are brackets for this, like stronger versions of how you would attach railing posts to a slab? Suggestions? Thanks in advance.
tpagel is offline   Reply With Quote
Old 04-14-2011, 11:19 PM   #2
Rewards Points: 5,336
Simpson has a variety of post to concrete connectors. Check out their website. You want the one that keeps the post off the concrete.
Ron
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 10:06 AM
attaching a new foundation to a stone foundation PLS Building & Construction 2 03-03-2011 11:25 PM
Need to level top of existing foundation wall BigJimmy Building & Construction 1 10-18-2009 09:10 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
Permanent Wood Foundation Question opee Building & Construction 2 03-19-2007 10:27 AM
