Old 10-02-2012, 01:08 PM   #1
Attaching wood to metal
I want to build a wall in my basement. My house is modular so the joists in the basement are a heavy metal. I have no idea how to attach the wood walls to the metal joists. What tools do I need? Screws, bolts , what??
jmagnah is offline   Reply With Quote
Old 10-02-2012, 01:11 PM   #2
Average Joe/ex-Navy IC3
gregzoll's Avatar
Pictures help. You would actually need to have someone weld brackets for mounting the wood timbers, or just build the timbers in a way that they are not attached to the units laying on the concrete walls. You basically would build a box that is only attached to the walls, not the modular living units.
: Now listen, Cadet. I've got a job for you. See this button?
: Don't touch it! It's the History Eraser button, you fool!
: So what'll happen?
: That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
Old 10-02-2012, 05:40 PM   #3
Is this wall paralleled or perpendicular to your metal joists?
Are they metal Joists or metal beams?
mae-ling is offline   Reply With Quote
Old 10-02-2012, 06:39 PM   #4
Self tapping screws should go thru it.The screws with a cutter end on it.
scottktmrider is offline   Reply With Quote
Old 10-02-2012, 08:12 PM   #5
this is what we use sold at box stores the little wings cut slightly larger hole in wood to prevent screw jacking
http://www.homedepot.com/h_d1/N-5yc1...1#.UGuCP01X3m8
be careful my advice only comes from general knowledge i know about the 4 rules it takes to plumb and they are
1 poop needs to flow down hill. 2 hot on left cold on right
3 i get a pay check on Mondays 4 do not chew finger nails at or after work.
jaydevries is offline   Reply With Quote
Old 10-03-2012, 09:33 AM   #6
Fastening wood to steel is done often in commercial construction using powder actuated equipment such as Hilti or Ramset.
rustyjames is offline   Reply With Quote
Old 10-03-2012, 09:39 AM   #7
Frustrated DIYer
How thick is the metal? If it's thin you can easily drill and screw the wood for framing, then you can attached the board for the wall.
Obn2012_Aus is offline   Reply With Quote
Old 10-03-2012, 12:08 PM   #8
Since it is a modular the undercarriage is heavy duty metal beams. The wheels are removed then the home is placed on the basement but the beams stay. Regular stick built homes have wood joists (I'm not sure "joist" is the correct term) in the ceiling of the basement but in modulars they are metal beams. The wall would be attached to the metal beams in the ceiling just as you would in any regular basement, I just don't know what to use since obviously regular screws or nails will not work.
Old 10-03-2012, 12:13 PM   #9
You can use the self tapping screws as stated above, although you may need to drill smaller pilot holes anyways.
Or metal screws that you will need to predrill for.
Go into a reputable hardware or lumber store and they can help you. Usually not a big box store.
Old 10-03-2012, 12:15 PM   #10
Experienced
Jackofall1's Avatar
This would be a good one to post pictures of, it would certainly give us an idea of exactly what you are trying to connect to.
Mark
Old 10-03-2012, 12:27 PM   #11
Usually like this, wood joists run front to back on top of it.
Old 10-03-2012, 12:34 PM   #12
Experienced
Jackofall1's Avatar
Thats kinda like I was invisioning, what I was trying to picture is whether they would be fastening on the horizontal (bottom flange) or on the vertical (web). Need to answer that question to best determine a means of fastening.
Mark
Tags
basement, metal joists, wall
Metal strap on wood framing. Can I cut it? monteconde Carpentry 3 08-06-2011 09:59 PM
Ready to paint the porch! Oil or latex? Leah Frances Painting 8 07-26-2011 08:29 PM
Attaching metal flashing to Faux stucco sdcurt Roofing 3 10-10-2010 05:51 PM
metal or wood studs? pwise Carpentry 7 01-21-2009 12:08 PM
Do I need to replace a rotten sill plate met Carpentry 8 07-11-2008 10:14 AM
