Attaching Two Masonite Boards/question - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-17-2010, 06:03 PM   #1
Smile
Attaching two masonite boards/question
Is there a way to attach two masonite boards to each other? I am making preschool room dividers. They need to be light weight, cheap, paintable, able to stand up (which is why I thought of hinges), easy and quick to make, and very portable. I would like to be able to fold them up and put them away if possible. They will be used as "walls" and will have the same things you see on preschool room walls like displays and such.
Is there a better wood to use? Any help and advise would be greatly appreciated. Thanks!
Trishas5 is offline   Reply With Quote
Old 07-17-2010, 06:10 PM   #2
Rewards Points: 5,332
You can use hinges, just use nuts and machine screws instead of wood screws to attach the hinges to the masonite.
Ron
Old 07-17-2010, 08:08 PM   #3
Thanks so much!
Tags
hinges , wood room dividers
Beware Masonite doors Jeremy Hillary Boob, PhD Building & Construction 14 03-14-2013 10:01 PM
Masonite Siding Replacement kennykenny Remodeling 2 07-20-2010 04:52 PM
Hardie over Masonite siding??? canyonbc Remodeling 2 01-27-2010 08:57 AM
Can I tape joints on old masonite walls? ETD66SS Building & Construction 9 11-13-2009 05:09 AM
Masonite Doors Bob Smithtown Carpentry 3 03-30-2009 12:53 PM
