Attaching Two Gable Roofs Together - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-10-2011, 11:34 AM   #1
Question
Attaching two gable roofs together
I am trying to expand my kitchen but I am having trouble figuring out how to, attach two gable roofs that are 12 feet apart, coming off the back of my house. As you face the rear of my house, the gable on the left sticks out 12 feet from the back of the main house, the other gable on the right which is 12 feet from the left gable, sticks out 10 feet from the rear of the main house. If you need a better visual of the floorplan, you can pull up the website DonaldGardner.com, and the floorplan for The Baldwin is the floor plan I am working with.
I appreciate any comments
Semper Fi Marines
Mustang1 is offline   Reply With Quote
Old 01-10-2011, 05:13 PM   #2
Stay-at-home GC
You want to push the breakfast nook wall out? How far? You are trying to tie in the MBR roofline with the return gable around the chimney, is that correct?
Can correctly identify Shinola 3 out of 5 times*
*Under ideal conditions
Some days, my Life needs a Rewind/Erase Button.
CplDevilDog is offline   Reply With Quote
The Following User Says Thank You to CplDevilDog For This Useful Post:
Mustang1 (01-12-2011)
Old 01-10-2011, 05:39 PM   #3
Framing Contractor
That would be the great room with the fireplace according to the floor plan. It doesn't show that stick out 10'. It only looks like around 2'. How far do you want the breakfast nook out?
Joe Carola
Joe Carola is offline   Reply With Quote
Old 01-12-2011, 06:19 AM   #4
Yes that is the great room. Sorry I forgot to mention that the fire place is not there, just 2 french doors and 2 windows. Also there is a screened in porch on the back of the great room which is 15ft 4in X 10ft, with a concret slab footings and a gable roof. Trying to push out kitchen between the master and screen porch 12ft. The screen porch extends out 10f and the master 12ft from the house.
Thanks so much
SgtMaj USMC
Old 01-12-2011, 06:21 AM   #5
Yes that is the great room. Sorry I forgot to mention that the fire place is not there, just 2 french doors and 2 windows. Also there is a screened in porch on the back of the great room which is 15ft 4in X 10ft, with a concret slab footings and a gable roof. Trying to push out kitchen between the master and screen porch 12ft. The screen porch extends out 10ft and the master 12ft from the house.
Thanks so much
SgtMaj USMC
Old 01-12-2011, 06:53 AM   #6
Stay-at-home GC
Construction started or still in the planning phase. Have you purchased that set of prints or just considering them?
Old 01-12-2011, 07:37 AM   #7
No construction started planning phase still in progress. Want to move on addition soon. No prints at this time.
Old 01-12-2011, 07:54 AM   #8
Framing Contractor
You put a shed roof between the two gable roofs for the new kitchen. You'll have a valley on each side where the shed roof hits the two gable roofs.
Joe Carola
The Following User Says Thank You to Joe Carola For This Useful Post:
Old 01-12-2011, 08:04 AM   #9
Framing Contractor
Here's a quick drawing of the shed roof rafters from the rear view.
Joe Carola
Old 01-12-2011, 08:06 AM   #10
Framing Contractor
You want the shed roof to have minimum 4/12 pitch without the top of the shed roof being higher than the ridge of either gable.
Joe Carola
Old 01-12-2011, 12:39 PM   #11
Joe, I relly appreciate this, your awsome. Thanks for the pic also. This really helps!!! Duane Guise
Do I need the gable vents bjakeski Roofing/Siding 4 08-17-2010 05:17 PM
Insulation in roof rafters at the gable end nofx1981 Roofing/Siding 5 03-09-2010 03:21 PM
Gable fan and Whole house fan jckkcj Roofing/Siding 8 08-26-2009 12:55 PM
HELP!! gable roofs( different sizes) bullipapu Roofing/Siding 1 08-13-2009 06:35 AM
Big trouble with gable vents! Beth777 Building & Construction 9 08-11-2008 07:32 AM
