Attaching Speakers To Cement Fiber-board Siding - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-20-2013, 01:39 PM   #1
Attaching speakers to Cement fiber-board siding
Our new home has cement fiber board siding which I haven't worked with before.
I want to install outdoor speakers. Are there special screws to use or would wood screws work just as well?
Thank you.
Walkinwood is offline   Reply With Quote
Old 03-20-2013, 01:44 PM   #2
Rewards Points: 34
You can use any screws that won't rust and are long enough to grab the sheathing. Predrill the holes in the siding. It will make driving the screw much easier.
djlandkpl is online now   Reply With Quote
Old 03-20-2013, 03:24 PM   #3
Rewards Points: 13,748
I'd be looking for another way to hang them.
Waters going to find it way in at some point, unsealed Hardee Plank falls apart when it gets wet.
Old 03-20-2013, 04:13 PM   #4
AHH, SPANS!!!
Rewards Points: 1,166
install speakers to studs behind the siding and seal all penetrations with quality sealer, ( caulk). can't always rely on there being a solid sheathing behind the siding except possibly on the corners of the house, blackboard is a real popular sheathing and will not prevent pullout from occurring.
hand drive is offline   Reply With Quote
Old 03-20-2013, 07:28 PM   #5
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,214
you should be installing mounting blocks on the wall before the siding goes up.. then you side up to the block..
use stainless steel screws to anchor the speakers
woodworkbykirk is offline   Reply With Quote
Old 03-21-2013, 01:35 PM   #6
MATT DIY
Wink
Sometimes it's hard to hang things level and securely outdoors as well. I hung 4 speakers outdoors recently using this hardware Ad removed- I hung them to wood studs on my covered patio...
matt_diy is offline   Reply With Quote
Old 03-21-2013, 04:11 PM   #7
Thanks all for your suggestions. I know there is sheathing (OSB) behind the siding, but not sure about blocks in place. I will get at least one screw of each speaker mount into a stud and make sure to caulk any holes I have made in the siding.
Thanks again.
Cement board at tub lip Homerepairguy Plumbing 18 02-22-2013 09:13 PM
a few quick questions about shower cement board and hydro ban diy'er on LI Tiling, ceramics, marble 2 04-27-2012 10:16 PM
Foam board over old 4in thick fiber board roofing panels Rebob40 Roofing/Siding 2 03-05-2012 09:24 AM
"Maintenance Free" Siding Materials (Vinyl, Steel, Fiber Cement) diggitydog Building & Construction 12 01-23-2009 04:24 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 01:07 PM
