Attaching Shed Style Roof Between Existing Buildings. - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-26-2011, 01:05 AM   #1
Dusty
Chutzie's Avatar
Wink
Attaching shed style roof between existing buildings.
Hello all~
I've been searching for some help on this problem and this appeared to be the friendliest one around. I've worked around the construction industry for nearly 35 years and have a pretty good working knowledge of home construction. But I've run into a problem I can't resolve. Here's the scenario...
About 18 years ago we build a 1 story rambler style house. As kids and grandkids move in and out we needed room for Our toys. So, we built an addition as a separate building and had future plans to connect the two. Well, the future is now!
This separate building is lovingly called the 'Cabin' and it's foundation is exactly 12' from, and parallel to, the long side of the main house. We're in the process of beginning the connecting Room which is a 12' X 14' and it will be a hallway between the House and the Cabin. We are up to laying sheathing down on the joists, with insulation installed as we go. Still with me..I hope?
The issue I'm concerned about is the roof on the new Room. Both the cabin and the house have regular peak roofs with 2' soffit and 8" cedar fascia. The new Room will have a shed-style roof with enough slope to run off the rain. We have enough room under the soffits to have a normal height room without any to spare. The soffits/fascia are limiting here. My roofer of many years is exceptionally good so I'm not worried about keeping it water tight. He did say to go ahead and leave it flat but I'd prefer at least a couple inches of slope for reassurance.
What I am concerned about is joining the slope edge of the new shed roof against the side wall of each existing building. We have stripped the siding down to the house wrap where the new room will be. Picture two buildings 12' apart. Now take a shed style chicken house or loafing shed and drop it in between the two buildings with the slope going the length of the opening. I hope I've described it clearly enough.
I'm looking for thoughts or ideas on
1) the best way to but the roof edge to the existing walls
2) things I've missed that will cause me grief later
Thanks in advance for your thoughts~
Chutzie
Chutzie is offline   Reply With Quote
Old 07-26-2011, 07:09 AM   #2
DIY staff
Rewards Points: 7,174
Pictures or photos will be needed to get any decent suggestions----Mike---
Old 07-26-2011, 12:31 PM   #3
Residential Designer
AndyGump's Avatar
Rewards Points: 684
Send a message via Skype™ to AndyGump
Some thing like this might work.
Andy.
AndyGump is online now   Reply With Quote
Old 07-26-2011, 01:58 PM   #4
Dusty
Chutzie's Avatar
Will get picture/photo uploaded soon~
Andy...you have the exact footprint! What we thought we'd do is to make a shed style roof 'under' the soffit area instead of your more esthetically pleasing idea of blending it in with the existing roof lines. We currently are relying on our own skills to finish up this project and although I know how to blend rooflines I'm not so sure this aging body will cooperate. That's why the shed roof seemed the easiest way to go.
Old 07-26-2011, 04:16 PM   #5
Dusty
Chutzie's Avatar
I hope this picture gives the idea. I took a photo this morning then into Photoshop and did some freehand sketching where the new walls and roof are going. The soffit and fascia height appear to be in the way but we've done careful measuring and it will fit. We're considering meeting the roof up with the fascia at the highest end. (the Front) and boxing in under the fascia to avoid unwanted critters, etc. The roof elevation difference from front to back will be 2-3 inches, just enough for runoff.
A little unconventional, I admit, but that's how I live life.
Chutzie
Attaching shed style roof between existing buildings.-web-room-drawn-pic-img_7.jpg
Attaching a shed roof to an existing roof. JMcLaughlin856 Building & Construction 2 03-13-2011 09:25 PM
Tie a shed roof into existing 6/12 roof jj1122_2000 Building & Construction 1 02-18-2009 09:37 PM
The moving Ice Dams after using a roof rake ?? Canufixit Roofing/Siding 9 02-05-2009 07:33 PM
Addition and Roof Replacement lebeld Roofing/Siding 4 01-04-2009 06:11 PM
Attaching lean to patio roof to existing roof Jackhammer Roofing/Siding 3 05-27-2008 07:13 PM
