Attaching Pump Jack Braces - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-04-2011, 07:54 PM   #1
Mr. Handy
Rewards Points: 16
I have never used a pump jack before but when attaching to a roof, do you lift up a tab of the shingle, attach brace with screws and once finished, remove the screws and just let the shingle tab drop back into position or do you use some sort of adhesive?
swiederin is offline   Reply With Quote
Old 08-04-2011, 08:10 PM   #2
Rewards Points: 282
its always good to put some asphault/rubber based roof patch AND drive an oversized flathead nail through the hole. then shingle on top....that should be leak free.
i like having a mechanical fastener in the hole (ie the nail) to take up space rather than just a hole, or goo.
jcrack_corn is offline   Reply With Quote
Old 08-05-2011, 06:21 AM   #3
BUILDER / REMODELING CONT
buletbob's Avatar
here is what we do.
We cut a small 3x3 patch of ice and water and peel the backing from it and then slid it under the shingle with the hole lay the tab down and then fill the hole with black jack and lay the next shingle tab down into it. you could also slide a piece of step flashing under the shingle tab.
Old 08-05-2011, 02:54 PM   #4
Rewards Points: 282
Originally Posted by buletbob View Post
here is what we do.
thats better than the original plywood/osb! nice.
Sump Pump Questions henlij Plumbing 22 03-16-2015 10:00 PM
Sump pump operation MikeKy55 Plumbing 16 05-11-2011 04:35 PM
Well Pump Problems dannyjoe Plumbing 6 10-01-2009 06:10 PM
Modification to an existing pump switch DRBLKJK Electrical 10 08-23-2009 03:06 PM
Jack Pump Scaffolding ovahimba Tools 2 02-23-2008 01:34 PM
