Attaching Porch Column To A Flush Beam - Building & Construction - Page 3 - DIY Chatroom Home Improvement Forum
Old 05-19-2013, 04:35 PM   #31
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 2,820
Originally Posted by ModernDayDarwin View Post
Out of curiosity, what would the proper notching method be? I know that structural integrity is compromised if you notch more than 1/3 a piece of wood, but it seems like a column would need more surface area resting on a beam to transfer the load. Of course I think between the notch resting on the beam and bolts through the beam, it would hold.
Something like this?
Those are interesting thoughts also.... I would suppose it would also depend on whether that beam was solid, or how well it was laminated to itself. Intuitively, it seems it ought to be sufficient... but if I had big snow loads, I'd want an engineer stamping it I guess.
Best
Peter
MTN REMODEL LLC is offline   Reply With Quote
Attaching gable porch roof to wall grpie Roofing/Siding 1 02-23-2012 07:28 AM
Adding to Concrete Porch + Steps? 99altrade Building & Construction 8 08-01-2011 12:14 PM
Attaching Porch Railing to House Charleston Building & Construction 2 04-22-2011 01:28 PM
Replacing Porch Column base, what wood to use? Shamus Building & Construction 7 05-31-2008 12:29 PM
Basement Beam and Columns..... shamrock33 Building & Construction 1 03-19-2008 05:03 PM
