Attaching Porch Column To A Flush Beam - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-25-2012, 08:45 PM   #16
cortell's Avatar
Rewards Points: 504
Originally Posted by cjohnsonmn View Post
So how close do you have to be on the vertical alignment between the deck post on the frost footing and the porch post on the beam above? Do I have to dig a new adjacent footing if a porch post is not directly over the deck post? (My corner posts are right on but I need to fudge the two middle ones to get them evenly spaced. This came about because the porch roof was an afterthought --no cantilever of the deck at the corner. Its 9x21 ft with house ledger on two sides. Thanks.
Rule of thumb: the offset can be up to the depth of the beam. If you're using 2x8 beams, you can be off by 7-1/4".
cortell is offline   Reply With Quote
The Following User Says Thank You to cortell For This Useful Post:
cjohnsonmn (05-19-2013)
Old 05-18-2013, 03:08 PM   #17
This thread may be old, but it helped me a ton. This is awesome.
ModernDayDarwin is offline   Reply With Quote
Old 05-18-2013, 05:21 PM   #18
Roofmaster
Rewards Points: 2,210
Great Video. Your deck appears to be designed to hold an Abrams tank or two.
As far as the posts go, I would notch your posts so that 2/3rds sit on the girder, and one third continues down to the bottom of the girder, and gets lagged or through bolted to the girder. The bolts should have large flat washers under the head (And Nuts) which cut into the wood. Fastening the posts like this gives you the best of both worlds, good compressive strength, and good resistance to Moment (wind loads)
Your deck looks extremely well built. thanks for the video.
Old 05-18-2013, 05:56 PM   #19
GBrackins's Avatar
Rewards Points: 2,108
J,
any other way to do it? even Abrams need out of the weather sometimes .....
gotta run get a powerball ticket, if you don't see me on here you'll know why!
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 05-18-2013, 06:37 PM   #20
Roofmaster
Originally Posted by GBrackins View Post
J,
Dont bother, I just bought 20 bucks worth, and Im gonna win. If I do, I might take a day off from posting!
Old 05-18-2013, 06:43 PM   #21
Roofmaster
Irrelevant if I understand the question. The deck substructure transfers the vertical loads to the footings. Where the posts are located on the perimeter of the deck is irrelevant.
Old 05-18-2013, 07:53 PM   #22
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 3,786
Yes... Assumng your flush beam is adequetly sized for your post/pier spacing (and of course the expected imposed loads)
My question is how are you going to attach the posts to your flush beam.... considering shear issues.
MTN REMODEL LLC is offline   Reply With Quote
Old 05-19-2013, 12:13 AM   #23
GBrackins's Avatar
I myself would probably use a Simpson Strong-Tie ABU standoff post base with (2) lag screws
Gary
Old 05-19-2013, 07:48 AM   #24
Most examples of those show them connected to a concrete post. Is there a reason they couldn't be used in a wood-to-wood connection.
Old 05-19-2013, 10:18 AM   #25
Just to clarify, I was asking about the allowable offset placement of load bearing porch roof posts. Snow loads on roofs can get pretty heavy in Minnesota, and I dont think you can just position the posts anywhere over your substructure beam and footings - much less along a cantilevered deck perimeter for example. But maybe I'm wrong?
This really is a great post thread - pun intended - I've learned a lot. My next question will be about tying a porch roof into the the existing roof lines and pitches.... (probably should start a new thread for that?)
cjohnsonmn is offline   Reply With Quote
The Following User Says Thank You to cjohnsonmn For This Useful Post:
MTN REMODEL LLC (05-19-2013)
Old 05-19-2013, 10:18 AM   #26
What about something like this? My gut says "no" simply because there's no connection between the column and anything, just gravity and the steel.
http://i.imgur.com/neaI6Te.jpg
edit: removing the image hot link. Far too big to embed.
Old 05-19-2013, 10:21 AM   #27
As a rule of thumb, roof support over cantilever is a big no-no unless. Now if you had a professional engineer involved to verify the design, you can do some crazy stuff. Google "largest cantilever in the world" and you'll see what i mean.
Old 05-19-2013, 11:41 AM   #28
GBrackins's Avatar
there is no reason I know that they cannot be used with wood. Change over from anchor bolt to either through bolts or lag screws.
Gary
The Following User Says Thank You to GBrackins For This Useful Post:
ModernDayDarwin (05-19-2013)
Old 05-19-2013, 01:01 PM   #29
Out of curiosity, what would the proper notching method be? I know that structural integrity is compromised if you notch more than 1/3 a piece of wood, but it seems like a column would need more surface area resting on a beam to transfer the load. Of course I think between the notch resting on the beam and bolts through the beam, it would hold.
Something like this?
Old 05-19-2013, 04:30 PM   #30
Interesting.... I'm not an engineer and don't know.... certainly better than toe-nailing it though
Best
Peter
Attaching gable porch roof to wall grpie Roofing/Siding 1 02-23-2012 07:28 AM
Adding to Concrete Porch + Steps? 99altrade Building & Construction 8 08-01-2011 12:14 PM
Attaching Porch Railing to House Charleston Building & Construction 2 04-22-2011 01:28 PM
Replacing Porch Column base, what wood to use? Shamus Building & Construction 7 05-31-2008 12:29 PM
Basement Beam and Columns..... shamrock33 Building & Construction 1 03-19-2008 05:03 PM
