Old 11-10-2009, 04:56 PM   #1
Attaching Ply-Bead Panels to Interior Wall
I'm installing Ply-Bead beadboard panels (essentially 1/2" plywood with beads cut into it) in my bathroom. Going from floor to ceiling, not half-wall. Started installing with 4d box nails but I think they might pop out over time, and I'm having a hard time countersinking them properly (need a smooth finish for paint).
Any recommendations? Finish nails? Screws? Thanks.
thebigsee is offline   Reply With Quote
Old 11-10-2009, 07:47 PM   #2
Make sure that you are nailing into studs. The joints should land on studs. You may need to cut them to make this happen. Also, I like to rabbet out the base board and chair rail to help keep a clean look. Finish nails should have been used and then countersunk with a nail set.
Josh Jaros Remodeling in The Woodlands, Texas
jaros bros. is offline   Reply With Quote
Old 11-11-2009, 08:50 AM   #3
Remodeler
fulline's Avatar
Not knowing exactly what product you have, glueing and nailing is the best. Jaro's is right about hitting the studs, but unfortunately depending on who built the house, those studs may not be where there supposed to be. The glue will take care of that problem. Construction glue that comes in a caulking tube works well.
Hope this helps.
fulline is offline   Reply With Quote
Old 11-12-2009, 11:24 AM   #4
Thanks for the responses. I ended up setting all the box nails with a nail set (took a long time, some nailheads fell off). Went over the boards again with trim screws in strategic locations to secure it to the wall tightly. Lots of holes to fill and sand before painting!
Tags
beadboard, nails, ply-bead, wainscoting
Replacing 2 Sub Panels with 1 Larger Panel GuitarJack Electrical 7 08-25-2009 09:43 PM
Bead boards - not panels cdavidl Carpentry 5 05-17-2009 04:13 PM
Paper faced Metal inside/outside corners? slinku2020 Remodeling 6 03-20-2009 11:16 PM
attaching corner bead to metal studs ar2736 Building & Construction 2 10-28-2008 12:32 PM
