Attaching New Riser Faces To Existing Stairs - Method? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-07-2013, 10:01 AM   #1
Dave88LX's Avatar
Rewards Points: 566
Attaching new riser faces to existing stairs - method?
Should I be using Liquid Nails? Wood Glue? Screws? 15 gauge nails?
Some combination of the above?
Dave88LX is offline   Reply With Quote
Old 05-07-2013, 10:33 AM   #2
MJ Force's Avatar
Rewards Points: 150
If your just resurfacing the existing risers with a thin veneer, then a good construction adhesive will do. It can also bond quickly and won't leave any nail holes. If your replacing the risers then use screws and construction adhesive. No squeaks or creaks this way.
MJ Force is offline   Reply With Quote
Old 05-07-2013, 11:38 AM   #3
Dave88LX's Avatar
Rewards Points: 566
I'll be adding 3/4" hardwood on top of the treads, and 3/4" "faces" to the risers...
Old 05-07-2013, 12:47 PM   #4
MJ Force's Avatar
Rewards Points: 150
Ok, so if its not structural I would glue and nail. The same for the hardwood nosing if your using one. 15ga finishing nails shot at a slight angle are best but will leave the largest hole to fill.
Screw down the existing stair treads first to prevent any possible creaks unless they were previously glued and screwed.
Should I replace wall skirt when installing new retro treads on existing stairs hkeiner Carpentry 12 02-15-2013 07:21 PM
Attaching 1/4" faux brick to drywall - Best Method? luv2mod Remodeling 1 10-06-2012 08:55 PM
joist repair sister method existing floor jmccarthy121 Building & Construction 2 07-27-2012 09:42 AM
Concrete steps with one side against wall oxicottin Building & Construction 12 10-14-2011 02:12 PM
Best Method for attaching decking lateral support getzjd Building & Construction 2 05-19-2010 06:45 AM
