Old 06-11-2012, 11:39 AM   #1
Attaching metal knee wall to CMU wall.
I’m thinking of placing a new decorative knee wall (5ft tall) on top of a building. I want to use metal studs for the framing. I’m also going to brace it to the roof (flat).
My question is: How to I make a secure transition from the top of the block to the metal studs?
Bass283 is offline   Reply With Quote
Old 06-11-2012, 11:42 AM   #2
Architect
Not interested in extending the block up?
If you are set on steel studs, then I would suggest you grout fill the top couple of block cores and wet set some threaded rods. Once set, run a wall plate with bolted connections to the threaded rod.
Since this sounds like a parapet condition, don't forget your wind loading. The lateral forces on that parapet may be significant.
How are you addressing the roofing?
jcarlilesiu is offline   Reply With Quote
Old 06-11-2012, 11:54 AM   #3
Thanks for the reply.
I am using faux stone for the face instead of block. Also, I am not set on steel studs, I figured it would be better than use wood since it would be exposed to the weather.
since its a new construction, I was having my roofer weld studs to the joists so I could attach one end of the brace.
Old 06-11-2012, 12:10 PM   #4
AHH, SPANS!!!
a lot of times vertical plywood sheathing that goes a few feet either side of the wall break helps to connect two different walls together. this along with plate connectors, though if the wall underneath of your wall is already finished then this will not work
we always set a treated 2x4 plate bolted to the lower wall and then framed the metal wall on top of that.
hand drive is offline   Reply With Quote
Old 06-11-2012, 12:17 PM   #5
Architect
Steel studs are not adequate for exposure to the weather. They are steel, and though galvanized, not sufficient for exposure.
I would consider extending a 4" CMU block wall up, aligning the back face with the wall below, and then install a faux masonry/stone face to that to align at the front.
Trouble with staggered wall rightit Building & Construction 2 03-09-2011 07:23 PM
Attaching fence post to side of retaining wall? Drew328i Landscaping & Lawn Care 5 06-01-2010 08:53 AM
Framing stair knee wall... bparise Carpentry 6 11-14-2009 01:03 AM
Building knee wall in basement, best approach? RyanD Building & Construction 6 07-04-2009 02:07 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
