Attaching Lean-To To Stucco Home - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-02-2012, 12:23 PM   #1
Rewards Points: 87
Attaching Lean-To to Stucco Home
My home is stucco over concrete block. Assuming I can get approval from the HOA, I'd like to construct a 4' x 8' lean-to for additional storage.
I would like to attach the lean-to to the exterior wall but since stucco is not exactly smooth, I'm not sure how to transition the walls and the roof of the shed. There are lots of "critters" down here and I don't want to leave a gap between the shed and the exterior of the house.
I'm not sure whether I'll use Hardie "stucco" board or have actual stucco applied to the structure.
Looking for ideas.
Thanks.
Tipsy
TipsyMcStagger is offline   Reply With Quote
Old 10-03-2012, 10:21 AM   #2
Rewards Points: 87
Any comments?
Tipsy
Old 10-03-2012, 10:30 AM   #3
Rewards Points: 12,808
If it was mine I'd be building a free standing shed with a shed style roof.
That way there's 0 chance of any wall damage.
mae-ling (10-03-2012)
Old 10-03-2012, 10:45 AM   #4
Rewards Points: 87
And leave a small gap between the shed and house? This might be the way to go but it seems there would be a lot of water, critters and debris finding there way into that gap.
Also, if I'm going to get this by the HOA, it's going to need to be very slim.
Tipsy
Old 10-03-2012, 11:52 AM   #5
Rewards Points: 2,202
Cut and remove stucco in the area of the 2x4's that will attach to the wall.
The finish the shed and stucco to match, yep very very difficult.
Basically treat it like an addition.
Or
Use treated stud against stucco and caulk it. Not the best.
mae-ling is offline   Reply With Quote
Attaching my garage to my home Schofieldfam Building & Construction 3 09-25-2012 09:17 AM
Attaching metal flashing to Faux stucco sdcurt Roofing/Siding 3 10-10-2010 05:51 PM
ledger stones on stucco wall, but wall is bowed rrauenza Building & Construction 7 05-18-2010 06:38 PM
Questions about painting and possibly adding siding to stucco house? krm27 Painting 3 01-19-2010 01:22 PM
Attaching Deck to Brick Home stubits Building & Construction 1 08-12-2009 12:54 PM
