Attaching A Horizontal Pipe Between Lally Columns - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-26-2011, 03:04 PM   #1
Lightbulb
Attaching a horizontal pipe between Lally Columns
I am trying to accomplish something simple but am not sure how to do it. I have two columns in my basement and I want to hang a pipe across them so I can do pull-ups.
Is there some kind hardware I could use to accomplish this? I don't care so much about the aesthetics. I just want the bar (pipe) to be rock solid so that it can support a couple hundred pounds when I'm exercising.
Any help would be appreciated. Obviously I don't want to drill into the columns.
DavidScubadiver is offline   Reply With Quote
Old 07-26-2011, 03:42 PM   #2
Civil Engineer
Rewards Points: 4,762
I assume the lally columns hold up a beam. I would recommend attaching the bar to the wood beam, easier and less likely to cause structural issues. Bolting through a lally column is possible, but much harder than attaching to a wood beam.
Daniel Holzman is online now   Reply With Quote
Old 07-26-2011, 03:44 PM   #3
Unfortunately, the ceiling is finished, and I thought I'd ask to see if anybody had ideas permitting a clamp or whatever, to be attached to the column.
Old 07-26-2011, 05:00 PM   #4
AGWhitehouse's Avatar
http://i00.i.aliimg.com/photo/v0/107...rap_Clamps.jpg
http://www.deadnutson.com/i/Fastener...ust_Clamps.jpg
http://www.freepatentsonline.com/6561473-0-large.jpg
Something like these with the right hardware & pipe will work...There are plenty of other types of pipe clamps that will serve a dual purpose of clamping and supporting. Try trolling around the piping sections of your local hardware store and see what you find.
Life's too short...so enjoy it!
AGWhitehouse is offline   Reply With Quote
Old 07-26-2011, 05:42 PM   #5
Rewards Points: 558
you can use a door chin up bar like this:
or something like this:
you can build your own:
build your one like this and put it in the garage:
epson is offline   Reply With Quote
Old 07-27-2011, 08:09 AM   #6
That last link is just the sort of thing I'm looking for. That kind of setup with a clamp around the bottom piece for added support would do the trick. I'll take a walk around the plumbing section at Ace and see if there is anything I can find. Thank you.
Old 07-27-2011, 08:11 AM   #7
Yes, thanks. I am aware of many different alternatives, but for a variety of reasons the most appealing one is to use the columns, if possible, to support the bar.
Tags
chin-ups , lally column , pull-ups
Remove Basement Lally Column? zslavin Building & Construction 10 08-18-2011 07:22 PM
Exterior Furnace exhaust vent pipe NeedHomeRepair HVAC 1 12-20-2010 05:17 PM
lally column loosed from basement floor sonofthetonsured Building & Construction 8 06-28-2007 01:24 PM
Concrete patch for lally column footing? AllGoNoShow Building & Construction 6 10-21-2006 08:16 PM
Adjustable lally column question... AllGoNoShow Building & Construction 2 10-13-2006 07:48 PM
