Attaching A Girder - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-28-2010, 10:43 AM   #1
attaching a girder
http://s684.photobucket.com/albums/v...10-sept038.jpg
http://s684.photobucket.com/albums/v...10-sept035.jpg
hello all:
I'm replacing my front porch and i was wonering where i should install my girder on these existing pier columns, the porch will be 36 inch above grade.
Now i was just going to attch a 2x12 along the front side of the columns like a wrap and then bolt through the block but that doesn't meet code requirements so if construct some joist hangers from steel and bolt them in along each side of the column and drop a triple 2x8 beam would that meet the requirements
or can i somehow support a triple girder off the inside of the columns using angle iron supporting underneth, i replaced some of the block as you see in the photos and there all filled completely with concrete
my porch is L shaped, along front is 30' by 8' feet depth and side is 16' back by 8'
any suggestions??
attaching a girder-2010-sept-035.jpg   attaching a girder-2010-sept-036.jpg   attaching a girder-2010-sept-037.jpg
kilby is offline   Reply With Quote
Old 09-28-2010, 11:13 AM   #2
Civil Engineer
Rewards Points: 4,938
I presume you know that bolting through the block does not meet code because you talked to the local code enforcement official. I suggest you discuss with the same official what would meet code. As the local enforcement official has final jurisdiction over code in your area, no one on this site can know what would or would not meet code in your area.
If you are planning to use the existing ledger board as part of your project, you may want to discuss that as well with the code official, it is hard to tell from the photo but the ledger looks like it might be compromised.
Old 09-28-2010, 11:30 AM   #3
he said i could just brace between each column and set my triple beam or girder in the joist brackets but I'd rather hang it from the back somehow
Ah maybe i'll make some steel brackets out of angle iron and make a u channel and fasten it with shiels into the conrete block, then hang my joist directly from that.
oh the ledger board is not big deal, it'll be replaced
How to replace 10"x6" Wood Girder and with the steel? What size it would be? Tzilya Building & Construction 1 07-28-2010 04:19 PM
Girder Steel or Wood Jameson1 Building & Construction 11 03-12-2010 05:38 PM
Girder Direction JeroldLopez Building & Construction 1 08-28-2009 07:38 PM
Garage storage, attaching to engineered beams jdcook72 General DIY Discussions 6 06-16-2009 11:01 PM
Supporting girder with wall Geber Carpentry 3 01-29-2007 09:53 AM
