Old 09-13-2009, 11:58 AM   #1
attaching garage loft support to 12 inch steel I beam
Hello All,
I'm planning to build a loft in our garage where the back edge will be supported by a 12 inch steel beam running along it's full length of 20 ft. I'm sure that the beam can easily support the weight of the loft by am not sure how best to attach vertical supports to the bottom of the beam. I hear of folks drilling or blasting nails into the beam, but would like to avoid a building inspector (or home inspector when we sell the place) giving me the sad news that I've weaked the beam.
Thanks in advance,
J.
lospinoj is offline   Reply With Quote
Old 09-13-2009, 02:25 PM   #2
Framing Contractor
Originally Posted by lospinoj View Post
Hello All,
Thanks in advance,
J.
Whoever designs the steel for you will show you how to do it and when you file for permits you will see if they pass. Or do you not plan on doing this without permits and inspections now before you sell your house?
Joe Carola
Joe Carola is offline   Reply With Quote
Old 09-13-2009, 10:43 PM   #3
Licensed P.E./Home Insp
Aggie67's Avatar
Yes, the best way to avoid a building inspector (or home inspector when you sell the place) giving you the sad news that you've weakened the beam is to design it correctly in the first place, and pull permits, and have the building inspector approve it.
Most folks don't realize that such modifications can be spotted a mile away, and that the buyer's home inspector's report will state "buyer should check for permits and final approvals on the following:..."
Aggie67 is offline   Reply With Quote
Old 09-14-2009, 01:16 AM   #4
Moderator
Termite's Avatar
Don't be so sure that the addition of a loft won't negatively affect the beam's load-carrying capacity. Don't let the fact that it is steel make you think that it has massive strength. Spanning 20 carrying tributary load is a lot to ask of any beam.
What do you mean by "vertical supports"? Are you somehow supporting the roof to the beam, or framing a wall over it, or what?
Old 09-14-2009, 02:38 PM   #5
Thanks All,
I'm taking no chances when it comes to permits and getting burned when it's time to sell this place. I already have a construction permit in hand and my town has stipulated that the support design must be Sealed by a Professional Engineer (I happen to be one, but will not stamp it myself to avoid any conflict of interest).
I have since found that a company called Thomas Betts, www.tnb.com, they make support struts and clamps for attaching structures to I beams.
I've not done the calculations yet, but my guess is that the beam will easily be able to support an additional distributed static load under 1000 pounds (coolers, holiday decorations, junk).
J.
Adding Microlam to garage, to support 2 doors and storage??? Shannon Building & Construction 8 10-20-2011 12:58 AM
Plans for a garage loft (large set of shelving) paul_2 Carpentry 10 08-16-2010 08:06 PM
Replacing existing wall with support beam or I beam sourdough Building & Construction 4 08-06-2008 10:42 AM
attaching 2X4's to garage floor Mr. Michael Carpentry 7 03-08-2007 09:48 PM
drilling a support beam sdmotor Building & Construction 1 07-12-2005 11:51 PM
