Attaching A Foundation - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-22-2008, 02:29 PM   #1
Attaching a Foundation
I'm looking at adding a 10' X 8' room to my kitchen. It will be a crawl space. 40" in hieght, 8" wide and a footing of 16" width and 8" height. How do I connect the new foundation to the old foundation. I realize I need to drill holes into the old foundation and use #4 bar or some of ther type of attachment. Do I need to use a type of weather proofing material between the new concrete and the old concrete. If so, what do I use? I a haven't been able to find good info on the internet or pictures to help with this. Is the weatherproofing installed before I poor the new concrete.
Dirtyron is offline   Reply With Quote
Old 01-22-2008, 04:30 PM   #2
if you excavate down to the bottom of the existing footer and drill 2-3 holes 6" to 8" deep around the center,then hammer in #4 or #5 rebar (depends on the size of your holes) and leave 8"+ sticking out into the new footer that should anchor it properly, although I would double check with your local code enforcement officer to see if they have any hoops for you to jump through
rocklyr is offline   Reply With Quote
Old 01-23-2008, 05:19 AM   #3
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,732
Ayuh,.....
The new Concrete itself should form a Tight Seal.......
Old 01-23-2008, 07:13 AM   #4
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Originally Posted by Bondo View Post
Ayuh,.....
yep...
- Build Well -
Old 01-23-2008, 05:32 PM   #5
Fill the hole w/epoxy then insert the rod...clean the orig. concrete well and brush some bonding agent on before the new pour.
cnydave is offline   Reply With Quote
Floor Joists Lifting Off Foundation Walls?! cbeingessner Building & Construction 2 06-12-2008 08:39 AM
Stone foundation for a small shack andrgo Building & Construction 10 09-13-2007 01:49 PM
I need help Re: Poured Slab Foundation - Moved to Plumbing alextina Plumbing 6 04-19-2007 04:35 PM
Addition Foundation /Build. advice wannabuild Remodeling 3 12-15-2006 06:28 PM
re-enforcing foundation - southern cal jhb Building & Construction 1 10-02-2006 12:15 AM
