Attaching Foam Exterior Concrete Wall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-06-2009, 10:28 AM   #1
Rewards Points: 16
Attaching foam exterior concrete wall
I am getting ready to insulate the exterior of my 10" poured concrete basement walls with 2" XPS rigid Styrofoam. The wall will be waterproofed with Bituthene sheet membrane above and below grade. The Styrofoam will not only insulate but will also serve as the protection board for the Bituthene. The above grade portions of the wall will be stuccoed with synthetic stucco.
The below grade portions of the foam will be held in place by the backfill. The above grade portions must be adhere with fasteners. All of the literature I've read about stucco recommends using Tapcons w/ washers that will fit flush against the foam. However, my contractor has suggested using a Ramset w/ washers, which I'm sure would be much faster and easier since the holes would not have to be predrilled. However, I'm not convinced that easier is always better.
I'm concerned about:
1) will the ramset nail be sufficient to secure the foam in the concrete and hold the weight of the board w/ m/l 1/4" of stucco on it?
2) can you ramset into the foam without destroying the foam?
My gut feeling is to go with the Tapcons as recommended but I would appreciate your recommendations here.
techinstructor is offline   Reply With Quote
Old 04-06-2009, 11:08 AM   #2
Rewards Points: 95
I would be concerned will having a dryvit type material over foam at the base of my house. That area takes alot of abuse. Every stone your lawn mower shoots up will be a hole in the stucco. Don"t even think about running your weed wacker down the edge of your house. I would put the stucco right to the concrete above grade and forget the insulation on the outside above grade.
NJ Brickie is offline   Reply With Quote
Old 04-06-2009, 11:26 AM   #3
Rewards Points: 16
That's not an issue. We don't plan to grow anything directly against the house. We're backfilling with course sand, then topping it with gravel around the 3' house perimeter. Two sides will be covered with porches and I plan to plant some shurbs on the outer perimeter of the gravel on the other sides so there will not be an issue with mowers or weed eaters.
Old 04-06-2009, 04:58 PM   #4
Rewards Points: 392
There are EIFS systems that are robust enough to deal with at grade issues such as stones, weed wackers, etc. There are also adhesives for gluing up the rigid foam. If it were me, I'd go with a few tapcons and washers too.
rustyjames is offline   Reply With Quote
Old 04-06-2009, 05:35 PM   #5
Rewards Points: 95
Yes there are. If they are placed on a suitable backing such as concrete, block, or brick. I have yet to see an EIFS system placed on foam that I couldn't easily puncture a hole in. EIFS manufactures state that foam should never be used below grade with their system. It creates an enviroment for all types of pests and bugs to live and breed. You will never know the problem exists because the exterior will look good. I stand by what I said. EIFS on foam over a house foundation is a bad idea period.
Old 04-07-2009, 11:01 AM   #6
Rewards Points: 392
There's a lot of building's around with EFIS systems on them with the foam at grade, that's all I can say.
Old 04-07-2009, 12:57 PM   #7
Concrete & Masonry
Rewards Points: 636
I wouldn't use eifs down to grade either, but it sounds like he isnt. He's talking about rigid polystyrene, not the cured, white beaded board behind EIFS. I've only done the bagged, fibered plaster intended for polystyrene once, & I'm not sure why, but it actually does hold up IMO for some reason. I would see if you can get your hands on the plastic washers used for EIFS, as the washer closes over the screw head as you tighten them, & they "rough" so the plaster will stick. I've seen them sold with the tapcon already assembled from a insulation wholesaler.
jomama45 is offline   Reply With Quote
Old 04-07-2009, 01:55 PM   #8
Rewards Points: 392
I should clarify that the XPS backed systems are much more durable than the EPS. I wouldn't use the latter at grade either.
Breaking up a long/continuous wall tigereye Interior Decorating 4 03-08-2009 03:43 PM
Loads on a partition wall acyate Building & Construction 8 02-28-2009 11:02 PM
attaching an additon room to vinyl wall visionary Carpentry 1 02-23-2009 06:32 PM
Gluing greenboard to cement wall... tips? AdamB5000 Remodeling 5 03-31-2008 10:11 AM
exposed brick wall Jrr1099 Carpentry 1 03-25-2008 02:45 PM
