Attaching Floor Joist To Solid Core CMU Basement Wall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-22-2009, 01:46 PM   #1
Attaching Floor Joist To Solid Core CMU basement wall
Which is the best way to attach the floor joist: to the top or the side of a wall?
jrepp is offline   Reply With Quote
Old 04-22-2009, 02:37 PM   #2
Concrete & Masonry
Rewards Points: 568
Definately on top of the wall, on a mud sill of course, & you probably wont need the hangers then.
jomama45 is offline   Reply With Quote
Old 04-22-2009, 03:19 PM   #3
Yes, I agree. On top of the wall. If you dont know you'll need to put a treated plate down on CMU and it must be anchored
into the block either with wedge anchors or threaded anchor that requires epoxy to glue it into the pre-drilled hole. Check
with your local code for depth and anchor size. Then you can build your joists on the plate and nail them in.
Jarrod is offline   Reply With Quote
Old 04-23-2009, 11:30 AM   #4
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
jr, Nice Illustration
Disclaimer
& Stay Safe
.....Bob Lavery
Old 04-23-2009, 11:36 AM   #5
Rewards Points: 150
Your house plans should show where,if you do it wrong you will be changing ceiling heights and lengths of drywall needed to finish.
Gary
Gary_602z is offline   Reply With Quote
Old 04-23-2009, 02:57 PM   #6
Registered User
Termite's Avatar
I suppose it could be mounted to the side of the wall on a ledger, but that would be because of some extenuating circumstance and certainly isn't the norm. 99% of the time the joists and rim joist sit on top of the foundation wall on a 2x6 treated mudsill.
Framing up a wall in the basement hankscorpio Building & Construction 7 11-28-2012 06:53 PM
Hole in new construction basement wall AprilQ Building & Construction 5 07-08-2008 06:14 PM
Basement Wall Construction-? Kim06 Building & Construction 1 04-06-2006 05:21 PM
Basement wall Problem dazusa Building & Construction 2 01-20-2005 09:16 AM
