-   -   Attaching Floor Joist To Solid Core CMU basement wall (http://www.diychatroom.com/f19/attaching-floor-joist-solid-core-cmu-basement-wall-43033/)
jrepp 04-22-2009 01:46 PM
1 Attachment(s)
Which is the best way to attach the floor joist: to the top or the side of a wall?
jomama45 04-22-2009 02:37 PM
Definately on top of the wall, on a mud sill of course, & you probably wont need the hangers then.
Jarrod 04-22-2009 03:19 PM
Yes, I agree. On top of the wall. If you dont know you'll need to put a treated plate down on CMU and it must be anchored
into the block either with wedge anchors or threaded anchor that requires epoxy to glue it into the pre-drilled hole. Check
with your local code for depth and anchor size. Then you can build your joists on the plate and nail them in.
PaliBob 04-23-2009 11:30 AM
jr, Nice Illustration
Gary_602z 04-23-2009 11:36 AM
Your house plans should show where,if you do it wrong you will be changing ceiling heights and lengths of drywall needed to finish.
Gary
Termite 04-23-2009 02:57 PM
I suppose it could be mounted to the side of the wall on a ledger, but that would be because of some extenuating circumstance and certainly isn't the norm. 99% of the time the joists and rim joist sit on top of the foundation wall on a 2x6 treated mudsill.
