Attaching deck stairs to brick patio
As you lay your deck out, I would remove the necessary pavers, and install posts to carry the bottoms of the stair stringers, consistant with the posts that you will set for the deck itself. Attach your stair stingers to them, leave the end ones up, to be cut to height for your hand rail, and cut the intermediate ones off, just below the bottom tread. It will require some additional steps to cut and fit the pavers back around the posts, but I would not go to the work of building a deck of that size, and reply on an uncertain component to carry part of the load.
