#1 |
Attaching deck to OSB rim joist
We have a 2 year old house that I need to replace the deck because we want a larger on and the current deck was put up by incompetent workers. They attached the ledger board right over the siding and just lagged it to the house. Needless to say it is frustrating.
But my question is, is the house uses engineered floor joists and the rim joist/ banding is 3/4 OSB I am fairly certain and I do not have access the rim joist or floor joists from inside the house since the basement is completely finished. Would it be ok if I were to use 1/2" x 4" lags to atatch the ledger to the house and just lag through the rim joist. The ledger is going to be a 2' x 10' x 19' feet so I was thinking of putting 2 lags every foot for a total of almost 40 lags in the ledger. The deck is about 5' 6" of the ground, would a free standing deck be viable? Only reason I am thinking about a free standing is there is a day light window in the basement under the deck and would prefer not to have a post right in front of it. Thanks a bunch, Chris |
#2 |
Licensed P.E./Home Insp
Check with your local construction official. They're going to be blessing it anyway. There are specially made brackets out there, and there are also bolting schemes, but it's really all going to be up to what the inspectors will pass. It's a free phone call. But I doubt they'd pass lag bolts set in to a 3/4 inch OSB rim joist.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
| The Following User Says Thank You to Aggie67 For This Useful Post: | kwikfishron (04-26-2010) |
#3 | |
Attaching deck to OSB rim joistQuote:
dont believe the ply will fly
The older I get the better I was |
#4 |
Forget about attaching the deck to the house. Install a floating deck and eliminate all the issues associated with an attached deck.
Ron |
#5 |
Moderator
Run the plans by the local Inspector, as said. You may need any posts within 5' of the basement to dig as low as the house's footings, but you won't need a post in front of the egress window. Many Counties/Cities have a Building Department web site.
Here is the basic deck that may be safer than your existing: http://www.awc.org/Publications/DCA/DCA6/DCA6-09.pdf Be safe, Gary
Clothes taking longer to dry?
Clean the dryer screen in HOT water if using fabric softener sheets. They leave a residue that impedes air-flow, costing you money. Clean the ducting in the last six months? 17,000 dryer fires annually! |
| Display Modes | |
| Space between joist and beam on deck | schveiguy | Building & Construction | 11 | 09-08-2009 10:15 AM |
| Attaching deck stringers to 2x8 rim joist | dgspurgin | Carpentry | 12 | 07-15-2009 08:15 PM |
| one rotted deck joist to replace, need advice | dougq | Building & Construction | 10 | 07-07-2009 03:18 PM |
| replacing rotted sill plate and rim joist behind a deck ledger board | tommyt | Building & Construction | 2 | 08-11-2008 08:38 PM |
| Deck Building Question - Installing Ledger Board to Rim Joists | Ler0y Jenkins | General Discussion | 20 | 05-18-2008 12:05 PM |
