Attaching Deck Ledger To House - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-24-2012, 04:27 PM   #1
Attaching Deck Ledger to House
Hi,
I know there are other posts on this, but I think my situation is a little different than those others.
I want to add a deck and attach it to the house. The siding is brick veneer. This means that I will have to attach it to the 1st row of concrete block below the veneer. There is parging on the the concrete block. The blocks are hollow, of course.
This raises a few issues:
1. There is no siding under which to put the flashing, so the flashing may not be totally waterproof.
2. What type of anchors to use. I have heard that expanding bolts would crack the hollow concrete block.
3. Will the existing parging effect things. Should it be removed ?
Thanks for insightful opinions !
Mike Mike is offline   Reply With Quote
Old 01-24-2012, 05:00 PM   #2
Rewards Points: 12,882
Make it a frre standing deck and all these problums go away.
pafred (02-03-2012)
Old 01-24-2012, 06:53 PM   #3
Registered User
Rewards Points: 4,936
Figs. 16, and 17: http://www.awc.org/Publications/DCA/DCA6/DCA6-09.pdf
Gary
Pro Advice: Repair or Replace Deck ledger board and joists? jdm001 General DIY Discussions 12 09-05-2011 10:46 PM
Install Flashing onto existing deck ledger, stucco home Ameekins Building & Construction 1 09-15-2010 06:51 PM
Questions on a deck I just built. stearns86 Carpentry 50 10-12-2009 11:17 PM
Installing deck ledger board over foam board? RickT Building & Construction 5 11-06-2006 11:50 PM
