Attaching Deck To Home - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-18-2011, 05:04 PM   #1
Question
Attaching Deck to Home
I am planning the construction of a large deck. The deck will be attached to my home that has brick exterior. The home has sheathing over studs behind the brick. I know there are several ways to attach a deck but what is the strongest practical way in my situation?
Attach to the brick?
Giles is offline   Reply With Quote
Old 02-18-2011, 05:10 PM   #2
Contractor - Renovations
fungku's Avatar
Brick veneer is not structural, so no.
I build a lot of decks and have never had to attach to a house that has brick veneer (it's very rare in my area for a home to have masonry veneer on the back of the house), so someone else that has dealt with it may chime in here.
Otherwise, I would build the deck "freestanding" that is probably the easiest solution, anyway.
How high off the ground is it, and what are the dimensions?
fungku is offline   Reply With Quote
The Following User Says Thank You to fungku For This Useful Post:
Giles (02-18-2011)
Old 02-18-2011, 07:22 PM   #3
Rewards Points: 212
free standing. In my area codes does not allow you to attach to brick veneer. Not only can the deck fail because veneer is not structrual but when it does fail it will pull the brick off the house with it. I know someone is going to come in and say it is ok to attach to brick veneer and tell you to use lag bolts or some kind of bolt and as long as you go into the rim joist it is ok but DON'T LISTEN TO THEM because behind the brick there is air space. so between the brick and air space there is about 5 inches of bolt (floating) and therefore the deck ends up resting on the brick anyhow
bluebird5 is offline   Reply With Quote
Old 02-18-2011, 08:41 PM   #4
Registered User
Rewards Points: 5,516
No can do, Fig. 17; http://www.lancova.com/deckinfo.pdf
Gary
Old 02-18-2011, 09:37 PM   #5
Gary
THANKS---Thats just what I was trying to find--Very informative!
Old 02-19-2011, 12:47 AM   #6
Registered User
You're welcome! Here is the 2009 update for that 2006 Deck Code; http://www.awc.org/Publications/DCA/...eckarticle.pdf
Gary
Ground level deck - screws or bolts? rsmith0399 Building & Construction 9 01-11-2012 12:53 PM
Deck Addition - Floating to Attached Foundation eemichael83 Project Showcase 15 08-22-2010 09:40 PM
Attaching deck to OSB rim joist Grifftech Building & Construction 4 04-26-2010 09:11 PM
Floating deck questions DIYguy2000 Building & Construction 6 04-23-2010 10:59 AM
Attaching Guard posts to deck joists rocketdoctor Building & Construction 4 11-10-2009 06:16 AM
