Attaching Corner Bead To Metal Studs - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-28-2008, 08:52 AM   #1
attaching corner bead to metal studs
Hi,
I framed my basement with metal studs and used 1/2in mold and milddew resistanst sheetrock. My questions are, how do I secure metal corner beads to the corners? I am concerned if I use screws, will they stick out too much? I don't want to use the metal imbedded in paper if I don't have to. Will the compound cover enough to use screws? And if so, what is the best screw to use? I also built a soffit around the duct work in the center, part steel and part wood. Any advice and tips would be great, I want to get this right.
Thank you very much.
ar2736 is offline   Reply With Quote
Old 10-28-2008, 11:41 AM   #2
Rewards Points: 150
use drywall screws made for metal studs. they have the red label. but the metal/paper corner beads are nice i think. no screws to worry about. use durabond mud.
drewhart is offline   Reply With Quote
Old 10-28-2008, 12:32 PM   #3
Drywall contractor
Rewards Points: 1,070
There is a tool made to "clinch" the corner bead onto the drywall (HD and Lowes both carry), but it is not the best method. Bead can easily be knocked loose. Regular 1-1/4" drywall screws can be used and should pull down so as not to cause a problem. I personally would use the "mud-on" paper/metal bead. I've gone to using it almost exclusively. Way less problems down the road.
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Paper faced Metal inside/outside corners? slinku2020 Remodeling 6 03-20-2009 11:16 PM
drywall corner bead drewhart Drywall & Plaster 2 10-22-2008 10:28 AM
corner bead on existing wall stallinc Building & Construction 12 01-30-2008 08:38 AM
Corner Bead....Metal or Plastic? yummy mummy Building & Construction 2 01-23-2008 06:11 PM
Flexible metal corner bead? Worth using? yummy mummy Building & Construction 3 11-15-2007 07:09 PM
