Originally Posted by hosscat
I would be better off building the carport detached and only attaching a small connector from the house to the carport.
Only if you don't mind it raining between the house and the carport.
Do I need to cut the house wrap and put the flashing on the inside of that as well.
You are correct.
Just remove all of the siding that's in the way of the carport, build it, roof it, then re-install the siding (you'll need some more J-channel). You'll have to carefully cut the corner post in place. be sure to install a kick out flashing when you begin the step flashing to divert water away from the house.
One other thing…In your first picture you show the ridge terminating into the corner of that window. That’s always a bad detail, avoid it if you can.
-NEW MEMBERS-
Please include your basic location in your profile. Some of the answers given are specific to a Region or State.
