Attaching Bottom Plate To Subfloor - Building & Construction - Page 5 - DIY Chatroom Home Improvement Forum
Old 02-24-2013, 09:33 AM   #61
Rewards Points: 83
Yeah an engineer is most definitely my best choice right now. The flooring was built for future construction I just didn't think about where the walls will sit. Depending on what the engineer says I have 2 options.
1. Land the new walls on a load bearing point.
2. Tie the ceilingceiling joists into the roof rafters.
#1 when likely change the room dimensions which I don't want to do.
#2 will add a lot of money to the project.
bduncan118 is offline   Reply With Quote
Rotten bottom plate advice!! Dirtyfrogg General DIY Discussions 4 10-18-2011 07:20 PM
Does anybody use/suggest Ramset pins for attaching base plate to cement? jobblyman Building & Construction 23 10-29-2010 11:39 PM
Need guidance on subfloor problems in new home. wb1026 Flooring 9 10-06-2009 06:29 AM
attaching top plate to existing ceiling derek9 Carpentry 5 07-30-2009 07:14 PM
