Attaching Bottom Plate To Subfloor - Building & Construction - Page 3 - DIY Chatroom Home Improvement Forum
Old 02-22-2013, 12:10 PM   #31
Rewards Points: 150
Or use 2x 6 and sister next to studs by nailing together
kaschmid3 is offline   Reply With Quote
Old 02-22-2013, 12:11 PM   #32
Rewards Points: 150
I would run them say way as rafters they would double up as collar ties
Old 02-22-2013, 12:17 PM   #33
Rewards Points: 83
Thank you so much for the help. But I'm lost on your last post. Are you saying run the ceiling joist the same way as the roof rafters? The reason I was doing this the other way was the span of the room is 21ft long by 14 wide at the biggest part. The room is L shaped. The long wall is 21ft
bduncan118 is offline   Reply With Quote
Old 02-22-2013, 12:19 PM   #34
Rewards Points: 83
Do you mean take a 2 x 6 and connect both walls together? That seems the easiest way to make it so its one cavity.
Old 02-22-2013, 12:24 PM   #35
Rewards Points: 150
U could always do non conventional top plates 2 x nailed to exterior wall with a 3 3/8 rip of 1/2 in plywood then another 2 x nailed to that so your top plates would be 3 1/2 by 3 1/2
Old 02-22-2013, 12:25 PM   #36
Rewards Points: 150
Yes connect the rafters on top of your top plates.
Old 02-22-2013, 12:26 PM   #37
Rewards Points: 150
Ps I want your attic
Old 02-22-2013, 12:28 PM   #38
Rewards Points: 83
The rafters are 10 ft or so above where the top plate will be. This is a video of the attic. I think it starts at 3:20 or so https://www.youtube.com/watch?v=XaFk...e_gdata_player
Old 02-22-2013, 12:50 PM   #39
Rewards Points: 150
Those little 2x up top are the collar ties connecting the roof rafters. U would want your new ceiling joists to connect the roof rafters at the height of your ceiling probably want 2x 6 since a long span. where it tees off just double up your furthest one I would even make those 2 a 2x8 and use joist hangers for the ones that butt into it
Old 02-22-2013, 12:53 PM   #40
Rewards Points: 150
That one 2x4 on an angle connecting ridge to gable wall is to Keep everything ridged so to replace that after ceiling joists r in put 2x4 on flat nailed into ceiling joist and butt into sheathing next to stud on gable wall and nail into stud
Old 02-22-2013, 01:35 PM   #41
Rewards Points: 83
That 2x4 is high enough to accommodate 8' walls.
Old 02-22-2013, 03:33 PM   #42
Rewards Points: 83
Im still thinking that I don't need to tie this room into the existing structure. Just build 4 independent walls on the subfloor. The ceiling joists of the new room will tie in on the new double top plates of the walls I am building. This is how the other room is that is already on the second story, however it is tied into the external wall on one side.
Old 02-22-2013, 03:51 PM   #43
Rewards Points: 150
Ok good luck. Ps nice size house and attic I'm a little jealous
Old 02-22-2013, 04:00 PM   #44
Rewards Points: 83
Thanks so much for the help! I moved in this house in 2010. The builder built the upstairs so you could build another room if you want to. The flooring is 2x10 16" on center with a span no bigger than 16' . This was done when the house was built. I am turning the room into a dedicated home theatre. I've got 2 walls up so 15% done with framing. Understanding everything is getting a bit overwhelming. I've researched the hell out of this project and just when I think I've got it all planned something else comes up that I haven't thought of yet. . . . Like not having a floor joist to nail the long well into, or the fire code. I am learning as I go.
Stage 2 is building a half bathroom and more storage to the right of the top of the steps. I may let a contractor do that part!
Thanks again for the help.
Old 02-22-2013, 04:06 PM   #45
Rewards Points: 150
No prob anytime it's what I do for a living and I enjoy it. I'm always willing to help someone who wants to learn. With this trade it's not about what I can build but how u can fix what u messed up( hopefully u only make that mistake once. I get to build custom high end housed on jersey shore. And some really old houses so I'm always learning. As i said good luck
The Following User Says Thank You to kaschmid3 For This Useful Post:
bduncan118 (02-22-2013)
Rotten bottom plate advice!! Dirtyfrogg General DIY Discussions 4 10-18-2011 07:20 PM
Does anybody use/suggest Ramset pins for attaching base plate to cement? jobblyman Building & Construction 23 10-29-2010 11:39 PM
Need guidance on subfloor problems in new home. wb1026 Flooring 9 10-06-2009 06:29 AM
attaching top plate to existing ceiling derek9 Carpentry 5 07-30-2009 07:14 PM
